06Jetta-Lane
Shortly after purchasing my '06 BRM Jetta, it has produced a white plume of smoke at startup. It's white and smells like fuel for the most part. Any sitting longer than 30 min and it's almost guaranteed to smoke. Started smoking around 245k miles and now at 265k. It seems there's 2 factors that make the smoke worse: 1) length of time parked and 2) temperature. If it has sat a full day, then it's guaranteed to produce a large plume. If it's under 40 F, it's also bad. It doesn't consume oil or coolant and never has since I've owned it. Within the past 5k miles I have installed a straight exhaust (no cat, muffler, or resonator), PD140 turbo, Colt Stage 2 cam, timing belt kit, SB Stage 2 clutch, 3bar MAP, EGR delete, ASV delete, and oil cooler delete. Injector lash and timing was set also. After all of this was accomplished, there was no affect on the smoke plume. This leads me to believe it may have something to do with the fuel injectors. I seriously doubt it's a head gasket since I've never seen a drop in oil quantity or coolant (I check both once a week). Any other possibilities I'm missing?
