Sootman
Ry,If anyone wants to try out an upgrade to this i have 2 'sizes' bigger, 210hp or 240 capable!! bolt on too!!
Are the upgrades turbos or nozzles?
I'm good for now, thanks.Turbo, I can PM you details if you like
I will get it to the dyno before long. I'm at 12k miles on the new turbo now and it still runs great. Just pops IC pipes off from time to time. Really need to upgrade. I did switch out my exhaust to 2.5" straight pipe from the turbo back. A little loud at time but not bad. Very curious what the numbers will be.Interesting reading and lots left to conjecture. I really like to see some solid numbers from a non-Mustang dyno.
I hope double rl will post a dyno soon.
Tough call on the EGR. I pulled mine when the turbo went in just in case it would be problematic. With RC 1+ on my car I got 140 HP and 238 ft/lbs on a conservative dyno with no other mods. I might suggest that you see what the car is like after you decide what to do about the EGR valve and a re-tune. You may want to consider using your stock injectors with the upgrade from DBW. Ask Jason about this, he's more knowledgable about his services. Getting the PD 150 injectors was a hassle and expensive. But I must say the power is there and the car is very smooth to drive.Sootman, I was in Madison Wi with Jason at his shop yesterday, and had the TB, Cam (lifters were dished 1-2 mm after only 83,000mi-we should all band together and have a class action just to recover the labor and parts-inexcusable), PD140 Turbo install, and ID Downipipe installed (nice looking piece!). After driving the 125 miles home I think I have developed the dreaded EGR Flapper valve bushing leak! I think the extra boost of the Garrett pushed the old valve over the edge. Should I replace or repair it, or delete it because with the bigger Garrett I shouldn't have manifold pressure problems causing boost spike and creep, that we have with the old stock Borg-Warner Turbo? As soon as I get the EGR valve system problem squared away I'll try to tune it on a dyno-jet with the stock injectors so we can get some apples to oranges hp/torque figures. Right now with the stock injectors, RC1 stock turbo DSG map, and 2.5"downpipe into the stock exhaust back (with resonator and back muffler), if I had to guess, I'd say I might be around 150-155hp and 270 ft/lbs at the wheels-maybe a little more. Even with a sick EGR it is still a VERY INTERESTING DRIVE! Can't wait to get some injectors on it with the proper tune from Jeff. Thanks for all your help
munisign
So far my IC pipes haven't been a problem but they sure were on my 2001, popped off all the time. Looking forward to see how it goes. I have about 5-8K now on the turbo and between that the injectors and cam things seem to be settling in.I will get it to the dyno before long. I'm at 12k miles on the new turbo now and it still runs great. Just pops IC pipes off from time to time. Really need to upgrade. I did switch out my exhaust to 2.5" straight pipe from the turbo back. A little loud at time but not bad. Very curious what the numbers will be.
That's strange. I have been running 29 PSI for about 30k miles and 25 PSI for about 15K before that and have been able to keep the stock IC pipes on once I got a good cold side connector to the turbo (different turbo that what you all are running). Now that I have the tune a d bugs all worked out, been really reliable....Just pops IC pipes off from time to time. Really need to upgrade...
What IndigoBlue said. It's aSouth Bend Stage 2 Endurance using the DMF. Very smooth and nearly as light as stock.That's exactly where I wanted to be when I got the car. Thanks for the guidance what I need. What clutch do you have in your car?
I have an OEM Sachs SMF... Wonder if it can handle this tq...It's aSouth Bend Stage 2 Endurance using the DMF.
Lets not talk about your curves. Though with 10k already on the setup I think you drive too much!The overall curves are as good as ever.
Bret,I really like what you have done with your car. Id really like to do the exact same thing with a few variations such as Malone tuning, dynamic egr control and dynamic idle control.
I have a few questions. When you replaced your cam shaft did you use OEM cam, or a colt stage 2 cam? I am also wondering why you switched to the PD150 injectors after buying used injectors? Were the used injectors PD150's as well? Im considering buying used BEW injectors with bigger nozzles and then getting them calibrated. Im also curious why you went with a south bend stage 2 clutch with a Dual mass flywheel? Would a single mass flywheel be better/cheaper?
The PD140 turbo is also something I'm looking at. I'm only concerned that it would be almost maxed out at 180hp. Have you done research into a custom intake for a larger turbo and potential cost?
Im looking into JS performance to have this work done. Where did you have your work done?
Thanks. -Bret
Yeah, it's like a Chinese puzzle. Hope you enjoy the new setup.I've got to add, I spent as much time getting the oil supply line out and the new one in as about everything else. PITA
I've had good results in all but one case with used PD150 injectors
we see stock PD150 injectors with 230bhp and 340lbs+ often.
Yep, stock PD 150 injectors with stock nozzles.Until I re-read this thread I thought you had PD150 injectors with larger nozzles. Im not sure why I assumed that. However I know you bought them new. I am searching for used PD150 injectors to save on cost, although Im concerned about the quality and reliability. But just to clarify the PD150 injectors with stock nozzles will produce 300ft/tq?? Thanks
Munisign sounds like you’re having lots of fun. I've been working on the same setup. I can’t wait to have my BRM tuned up. Yesterday my BEW injectors & Race 783's arrived in the mail. I already have my PD140 turbo, 2.5" downpipe, just waiting on my Franko6 stage 2 cam. SBC stage 2 & 14pound single mass flywheel is being installed today. Perhaps I should be looking into stouter valve springs??
