Hey all, sorry if this has been asked before, but I'm pretty new to working on diesels and turbos. Driving home the other night, about 2 miles from home, heard a decent amount of whistling coming from the turbo, followed by a pop and a ridiculous amount of white smoke pouring out behind the car. Pulled over immediately to find a significant puddle of oil on the ground after sitting for a moment (if it were my 07 Chevy truck I would have assumed an oil cooler line blew). Ended up towing the car home the last 2 miles. Car is a 2006 Jetta w/ a BRM & 5 Speed Trans.
Looked over the car last night to start diagnosing and found the following:
What things should I be looking at from here? I could try and post some pictures this evening if that helps. I've read about the oil supply lines leaking fairly commonly, but I wouldn't think that would give me the smoke screen I saw? I also don't want to assume that this is just a blown turbo if there's something else wrong with the whole turbo system.
- Oil level in car is at the "MIN" mark, so not catastrophically low.
- Turbo turbine/shaft on the inlet has a marginal amount of radial play - but not any axial that I can notice. (Not sure how to quantify it, I can maybe move the centerline of the shaft about 1/8" or so.)
- Oil staining down the exhaust seemingly starting around the area where the exhaust outlet on the turbo attaches.
- EGR cooler is definitely leaking from the valve, I had inspected this ~10,000 miles ago, and couldn't verify it, but there is soot around it now. Debating on delete vs. a Franko6 upgraded EGR cooler.
- Best that I could tell, all intercooler plumbing seems to be in order.
- Removed ASV and the EGR valve to try and see if there was an obvious source of the oil on the top side of the turbo, and didn't see anything definitive.
