feedupbrm171
hi everyone so I have a 06 brm that has just had a cam done along with new tandem pump with everything back together and timed torsion value is 0.0 - 0.5 the car will start then die like the value is out but then I can try to start it again and it will run ruff and I have to give it throttle to keep it running for maybe 3 mins the it will run fine after that can drive to work over 30mins running like nothing is wrong shut if off at work and go to leave will have to do the same thing to get it to run. once it is runnong and i shut it off it will start with no problems unless it sits for awhile. Also has a EGR block off and Kerma tune. Anything I should be looking at would help thanks.
