Standard bearings provide lots of oil under 3000 rpm and are not the problem.
If true, this is good to know - I rarely drive over 3000 RPM.
I've read through lots of threads - no one seems to have definitively nailed down the root cause of the problems PD's have with CAMS. Any updated information, testing, theories are welcomed.
Based on logic (perhaps flawed), some reading, and a less than scholarly level of engineering, my take is the root cause is the fundamental design: 12 lobes, on a short shaft - lots of pressure, minimal time between strikes, and narrow striking surfaces.
Overcoming this flawed fundamental design seems somewhat elusive. If you try to fix the problem by just making the camshaft uber-strong, it seems to me you'd just end up with a flawless camshaft, and chewed up lifters. I am not entirely convinced the Camshafts, in and of themselves, were the problem. They could have all been made to spec, and still have had the ensuing problems.
One way or another, the high pressure/high heat would need to be alleviated. It may be wishful thinking, but it does kinda seem like Frank06's strategy of re-routing the oil to the top of the shaft (where its under less pressure), and onto the lifters, would go some way to reducing heat build-up.
Unfortunately, cost does, in my case, have to play a role. I'd love to go with a Colt-Cam, or Frank06 cam, and could easily have done so in years past - but the introduction of a wife, a kid, and one very lousy investment have resulted in, well, "a failed cam".
The Chinese fooled me once (and it cost me half a million), but it won't happen again. No Chinesium for me. I do realize the Febi (and some other name-brand aftermarket parts) may very well be made in China - but this is not the same as no-name Chinese parts. The Western brand, Chinese-made parts are done so under the supervision, specs, and quality-control of the parent Western company. The Chinese are cheats, across the board - but they are perfectly capable of making quality parts, IF they are forced to. I-phones, for example, are all made in China....
