aNUT
First I've seen of the BRMs having valve train issues. The car in question is an '06 w/ 100K miles; Castrol TXT and SLX its whole life w/ 10K mile OCI.
The worst of the wear is on the #3 exhaust lobe. All other lobes are worn as well, though not to the degree #3E is. They all have a distinct edge on the trailing face of the lobe. They are wearing from parabolic to trapezoidal in shape.
The exhausts are worse than the intakes due to the increased pressure. The injector lobe on #3 has a pretty good divot in it, though all rollers are in good shape, including #3. Lifters all appear to be in OK shape, though all will be replaced when the cam goes in. The cam bearing shells are all fine.
The car as making a 'bupping' sound with no performance issues when it was brought to me. Upon removing the upper intake pipe @ the EGR, it was apparent that exhaust was getting blown back into the intake and making the noise. I believe that #3 was not fully emptying on the exhaust stroke because of the decreased valve lift. This gas remained traped until the intake valve opened on the intake stroke; at which point it vented into the intake.
Now the pics...Full sized images available by clicking the pic.
#3 exhaust lobe from above
#3 injector lobe
Another angle on #3E
EDIT 2.27.09 There are many more pictures on page 3.
EDIT 2.15.09 for ease of reference, torque specs and parts list have been moved to the first post.
BRM cam R&R parts list:
1x Cam - 038 109 101AH
8x Followers - 038 109 309 C
1x Valve cover gasket - 03G 103 483 D
1x Camshaft Seal - 038 103 085 C
10x Bearing - 038 103 673 B GLB
10x Journal cap bolt - 038 103 714
1x Tandem pump gasket - 038 145 215
8x Injector rocker bolts - 038 103 714 A
1x Oil cooler* - 068 117 021B
1x lower cooler gasket* - 038 117 070
1x upper cooler gasket* - 038 117 070 A
*These part numbers are for the ALH cooler which is identical from everything I can tell, but much cheaper than the BRM
1x Oil filter 071 115 562A
5l Oil
2l coolant ZVW 237 G12
It's a good idea to R&R and clean the oil pan as well. Also a good idea to remove the oil from the pools at the front of the head.
The above list does not include rockers, as these were not worn in my case.
Pertinent torque specs for a BRM cam R&R:
All torques are in ftlbs unless otherwise noted.
Always replace bolts are bold.
Oil pan: 11; seal pan with a thin bead of RTV.
Oil pan to tranny: 44
Oil cooler cap: 18
Journal Cap: 71inlbs + 90deg.
Rocker arm axle: 15 + 90deg.
Timing belt tensioner nut: 15 + 45deg.
Large tandem pump to head: 15
Small tandem pump to head: 7
Valve cover: 7
Valve cover tightening sequence:
___10__ 5___ 4___ 8___
1___________________2
13_________________12
9___7___3___6______11
Cam hub to cam: 74
*it is essential that the taper fitting is clean and deburred. Brake cleaner and a rag works well.
Cam sprocket to hub: 18
If I left something out, PM me, and I'll look it up and edit this post.
#3 injector lobe
5l Oil
Oil cooler cap: 18
Valve cover: 7
Cam hub to cam: 74
