Going to pick at the AC today, this is a code scan (got my CAN cable finally)
VCDS Version: Release 12.12.0
Data version: 20130910
Wednesday,25,November,2015,09:05:49:30570
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K25M618882 Mileage: 368740km/229124miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E1485560
Coding: 0050071
Shop #: WSC 01814 128 53366
VCID: 63C3DFCEA222D206E91-8036
1 Fault Found:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368749 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:36
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00001000
Temperature: 64.8°C
(no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A7D42AA7528F3CE9A7-806F
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CD1B4F24FFC9D7E58B-8039
2 Faults Found:
00402 - Auxiliary Air Heater Element (Z35)
004 - No Signal/Communication
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000033798
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F6B63FEBE6A26663D9-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
00483 - Control Module for Auxiliary Air Heater
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD011Y1.
Coding: 0012627
VCID: 2E557EFAB9602F6E36F-807B
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME084448414
Subsystem 3 - Serial number: 6342MSME07784F50I
Subsystem 4 - Serial number: 6351HSME0611591E4
Subsystem 5 - Serial number: 6361HSME06130E686
Subsystem 6 - Serial number: 63727SME0605047AZ
Subsystem 7 - Serial number: 63827SME053A1962/
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 L HW: 1K0 953 549 L
Component: Lenksäulenmodul 010 0040
Coding: 0000041
VCID: 3B7347AE7A12CAC6811-806E
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
VCID: 2C5174F28F7C5D7E18B-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C18016F
Coding: 3D3F0B400F1002
VCID: 295F8DE6808E4856E3D-807C
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 368749 km
Time Indication: 0
Date: 2000.00.00
Time: 20:58:46
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNGG103
VCID: F8F918A28BA4A1DE2C3-80AD
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 3665569A413017AE7EF-8063
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 30696082A354399E243-8065
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 377B5B9E463AEEA6659-8062
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 A HW: 1K0 035 180 A
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E3020370
Coding: 0040400
VCID: 1E35AE3AC9C0BFEE86F-804B
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 316F6586A85E30962BD-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326D6A8AAD580B8E527-8067
Address 7D: Aux. Heat
Cannot be reached
End ---------------------------------------------------------------------
