tassolake
This thread is those that are new to VW but not to automobiles and is inspired by my MAF, EGR, Cylinder head and turbo replacement issues on the 2006 VW. VW has unique vocabulary and nuisances, below is a quick overview of these irregularities. (My car is a 2006 TDI, PD with the BRM motor and a 5speed manual).
If you want to work on your A5 Jetta the following tools are mandatory
Term definition
What I have learned:
Final word of advice, please ask the knowledgeable experts on this forum for help when you are stuck. (Dan has talked me off the ledge a few times, Thank you Dan).
Happy holidays to all.
- VAG-COM software and cable
- Timing Belt tools (from Metal Nerd)
- Triple Square Sockets 4mm – 14mm (14MM is for the brakes)
- A complete set of Metric Allen Keys
- Suction tool (coolant, fuel return etc).
Term definition
- Lifters in VW language are the round disks found under the Cam and over the Valves (not the rockers used for the Injectors)
- Lift Pump is the in tank fuel pump which sends fuel to the Tandem Pump
- Tandem Pump is the replacement for the old injector pump and pressurizes the fuel in the cylinder head and located at the end of the cam
- Injectors are the Valve spring devices found under the valve cover with electrical connectors.
- MAF sensor with improbable value error codes is not related to MAF sensor; it is an early sign of cam and lifter failure. (Replace MAF and EGR to confirm such as I did, but it is not cheap).
- Following the factory maintenance schedule at the dealership since new, with the correct oil did not prevent the cam and lifters failing at 160,000Km (100,000 miles). Therefore yours will most likely fail as well.
- If the lifter comes completely apart and gouges the area around the lifter, a new Cylinder head is required.
- Cylinder head gaskets are sized for the Block not the cylinder head. Each gasket has a series of notches on the front of the gasket not covered by the head, replace with the exact same number of notches (apparently this is measured at the factory by how far out of the block the pistons sit after machining).
- Replacing the Cylinder Head is fairly easy compared to other brands (budget four hours to get out, One hour to swap over everything, five to put back in and two setting up the timing, or a complete weekend with beer breaks)
- Setting the timing for the Timing belt even with the special tools is not easy (Vag-Com is absolutely required for final timing adjustments)
- The PD Injectors are almost impossible to rebuild, but a quick dunk in an ultrasonic tank, without new parts does wonders for the units. (For those that tried to disassemble the injectors at home, like me).
- The Glow Plugs will break, just looking at them, always remove them before pulling the head (ask me about my new glow plugs)
- The turbo still had lots of life left at 160,000Km but it is much easier to replace when the head is off (no need to pull the EGR cooler or Driveshaft) (thank you to Cherry Turbos for the quick turn around).
- TDIForum.com is the absolutely best source for information on these vehicles and thank you to all the helpful advice when I was elbow deep into the engine.
- After replacing the Head / Timing Belt / Tandem Pump / Injectors, hard wire 12v to the lift pump under the rear seat for a few minutes to ensure there is no air in the lines (+12vdc to the .25” blade on the flat side, GND to the other blade). Crank the engine for at least 45 seconds to see if it will fire (don’t over heat the starter). If it still won’t fire, retard the timing a hair (loosen the cam pulley bolts, hold the cam in place (18mm socket) and using the metal nerd bar turn the pulley ever so slightly counter clockwise (1mm increments). Retighten the cam bolts and try again. Eventually it will start. Then use the VAG-COM (engine controller, fourth measuring block and the fourth value) the value should be -2.5 to +2.5. Keep adjusting the cam pulley until it is within this range (Car will start with -4.0 but will not start with +5).
