Breaking News: New VAG 504.00 & 507.00 standards
raybo
St. Petersburg, FL
2010 JSW DSG White Gold
This breaking news came out in 2005. How come there aren't more suppliers of 507 spec oil?
There aren't enough cars that use it. Shelf space is reserved for stuff that sells. In Europe, where half the cars are Diesel and a lot of those are VW, you can find it everywhere.
murozel
Turkey
2004 Seat Cordoba 1.4 TDI PD, Polar Blue
The dealer to whom I always take my car for periodic service used to put VW505.01 oil till a few months ago. The last time I went, I saw that the oil they use was 507.00 (5W30). When I asked about this change, he told me that according to the latest updates in the maintanence plan made by the manufacturer, the oil for PD engines was that stuff thereafter. Is that ok, or should I do something about this?
murozel
Turkey
Thanks for the answer. Well, since I go only to the authorised dealer, I trust them for the oil they use and do not question so much. However, since it is clearly emphasized in the manual to use 505.01 oil for PD engines, the different oil they used last time caught my attention. That's why I needed to ask.
Thanks again.
Regards,
TL A3
SD CA
2012 A3
I agree. VW makes the engine: provides specs.
It is only available through the dealers, because it is manufactured for them by the oil companies. It would then be up to the oil companies to make it available to every one else.
exactly. VW is at the cutting edge of diesel oil technologies. without engine, oil and fuel innovation diesels will disappear.
instead of getting bent out of shape about new VW oil specs, try smiling and being thankful that the company you support is constantly trying to balance diesel efficiency, real environmental concerns, and an excellent driving experience.
also, consider that you've bought a european car - primarily designed for europeans - which IMO is great. europeans are expected to be more aware of their automobile's needs.
Fred's is a TDI enthusiasts site and while a little "whining" about having to use an advanced OEM oil spec. is expected, the volumes and volumes of whining on this website amazes me.
If there's a record in the guiness book of world records for "most whiny posts in an auto enthusiasts forum" I bet the TDIclub Fuels and Lubricants forum has it!
And we're whining about technology enabling oil specifications
SamJammerTDi
Laurel, Md. USA
Mk4 jetta White automatic
Thanks again.
Regards,
You trust the dealer? It is noted quite often in this forum that quite a few dealers used the wrong oil for PDs and it is also noted that 507.00 does not perform well in the PDs either, do your own and use a 5w40 or supply your own Pentosynth HP2 (505.01) or Castrol TXT 505.01 from an Audi Dealer and if out of warranty use Mobil 1 Turbo Diesel Truck (TDT)
cookeze
Sacramento, CA
2012 Passat
Thank goodness Amsoil has stepped up to the plate by supplying 507.00 oil. A US supplier of US sourced synthetic oil. I've always been for supporting the small guy. I think they look out for us TDI small guys.
geodug
Vancouver, BC, Canada
2011 Golf Wagon TDI 6MT
I just had my fuel line dampers installed on my 2011 Golf Wagon under a VW recall. While at the dealer's in the Metro Vancouver area, I asked what oil they had for my car and the price.
They currently (April 2012) stock Castrol SLX Professional 5W30 to VW spec 507.00 and the price is $9.50 per liter.
pleopard
Calgary, Alberta
2010 Jetta TDI
Hi stormy, this relative performance comparison tool is known amongst some on this forum but for whatever reason, very little emphasis is ever placed on it. It's good to see someone else has taken notice of it.
TooSlick
Dixie
Audi 100S
If you look at those spider charts, the VW 504/507 oils look like the greatest thing since sliced bread. Yet they don't hold up well in VW/Audi, gas engine turbos and their performance in the PD diesels has been inconsistent. So I'd have to question whether they've achieved all the performance goals as defined by Lubrizol.
TS
stormy
Germany
Seat Leon 5F ST DSG 2.0TDI EA288
I have read about that over here in germany also, they also gave the oil the blame. Well seems obvious if a 2nd PD driven with 505.01 5W-40 doesnt show that wear...Any links on that?
But I think there where also 2 - 3 users of 507.00 with the PD that didnt have that extreme wear, I´ll go check that thread agian. Are there any records on this board about it?
Because basicly I was thinking the people gave the blame on the oil too fast because of these questions:
Oilchangeintervall?
Driving manner?
Engine allowed to warm up befor punching it?
Additives used either in Diesel or oil or both?
Did the PD have a series of "bad" cams fittet?
And even if it was the oil, it stays with the PD.
On the CR, to me, there is no big option on using something different. I had a talk with a Castrol technician about the Castrol Edge Professional Longlife 3. He said during warranty the only thing to use would be the oil stated above (ore any other 507.00) if I would want the cover. After that i could step "up" to, for example, the Castrol Edge Turbo Diesel 5W-40 with 505.01. So I asked him wich benefit it would have for my engine:
On long trips and spirited driving less oil consumption. He didnt say anything about wear. So I asked him if less oil consumption was the only benefit and he said yes :)
By the way those performance goals are defined by the manufacturer :)
Just my .2 cents, still kinda new to all of this diesel stuff :eek:
If it interests someone:
http://www.golf4.de/motortuning/139862-nockenwellenlager-hydrostoessel-probleme-pumpe-duese-tdi.html
jimbag
FL
2013 Jetta TDI
507 00 Liqui-Moly (Lubri-Moly) TOP-TEC 5W30 is available @ NAPA. The part number for a 5L jug is LM3707, and it sells for around $40.
Link
Adam Overmiller
US
no
VOLKSWAGEN gives oil standard some lubricant manufacturers releases for the new Diesel specification 507.00 and the new specification 504.00 for Otto engines gave. The Wolfsburg manufacturer published no details to the new engine oil standards still.
The new products "Shell Helix Ultra VX" and "Vapsoil 507 00" are applicable according to manufacturer in all vehicles of the company marks with Longlife service. It is mixable and on all valid extended oil change intervals (WIV) laid out with all usual oils. Besides provide the special additives - particularly suitably for the employment in direct injecting FSI engines for less abrasion at the highly loaded construction units and is at the same time appropriate for the use of soot particle filters.
In the context of the co-operation of Volkswagen AUDI partner service (VAPS) and Shell VAPS besides the Shell product will drive out.
Also, the new Castrol SLX LongLife III received the appropriate after-sales releases according to data of the lubricant producer after VOLKSWAGEN 504.00 and 507.00. The lubricant with "Clean performance Technology" on basis of a formulation of low ash is aligned to the requirements of diesel engines with particle filter, however according to manufacturer even for further models will in particular be applicable.
CAT Power
Clemmons, NC
2013 Beetle TDI; Tornado Red; Sunroof; 6 Speed DSG
Is there anyone who has a link to the complete list of 507 approved motor oils?
Strivin'
Trumansburg, NY
2011 JettaSportWagen-w/thanks to 3193; 2005 Passat Sedan
VW approved oil list
This listing was supplied by VW Customer care in response to a request I made of them recently for 507 qualified oils for my 2011 Jetta TDI Sportwagen. Sorry - formatting of the table was not carried over in my copy/paste attempt. Use "edit/find" in your browser to search the list. It's about 8 pages long!
"Attached, you will find the acceptable oil list for your Jetta SportWagen you requested."
502 00 - Gasoline engines
505 00 - Diesel engines
504 00 / 507 00 - Gasoline and Diesel engines​
Brand Name SAE - Spec. VW - Standard​
ACT Voltronic Motor Oil SAE 5W-40 50200/50500
AD Parts AD SDI SAE 5W-40 50500/50501
Adamol Adamol Multitop PDI SAE 5W-40 50200/50500/50501
Addinol Addinol Eco Light SAE 5W-40 50200/50500
Addinol Addinol Extra light MV 038 SAE 0W-30 50200/50500
Addinol Addinol Extra Power MV 0538 LE SAE 5W-30 50200/50500
Addinol Addinol Giga light MV 0530 LL SAE 5W-30 50400/50700
Addinol Addinol Light MV 0546 PD SAE 5W-40 50500/50501
Addinol Addinol Mega Star SAE 5W-30 50400/50700
Addinol Addinol Semi synth MV 1047 SAE 10W-40 50500/50501
Addinol Addinol Super light MV 0546 SAE 5W-40 50200/50500
Addinol High Star SAE 5W-40 50200/50500
Addinol Mega Light MV0539 LE SAE 5W-30 50400/50700
Adnoc Adnoc Image SAE 5W-30 50200/50500
Adnoc Adnoc Image SAE 5W-40 50200/50500
Adnoc Adnoc Pearl SAE 5W-40 50500/50501
Agip Agip 7004 SAE 5W-40 50200/50500/50501
Agip Agip 7008 SAE 5W-30 50400/50700
Agip Agip Extra HTS SAE 5W-40 50200/50500
Agip Agip Formula FUTURE SAE 5W-30 50400/50700
Agip Agip Sy nthetic PC SAE 5W-40 50200/50500
Agip IP SINTIAX 505 EXCLUSIV SAE 5W-40 50200/50500/50501
Agip Sint Evolution SAE 5W-40 50200/50500
Agip Sint Turbo Diesel Evolution SAE 5W-40 50200/50500
Agip Tecsint SAE 5W-30 50200/50500
Agip Tecsint SL SAE 5W-40 50200/50500
Aral Aral HighTronic SAE 5W-40 50200/50500
Aral Aral P 426 SAE 0W-30 50200/50500
Aral Aral SuperSynth SAE 0W-40 50200/50500
Aral Aral SuperTronic SAE 0W-40 50200/50500
Aral Aral SuperTronic G SAE 0W-30 50200/50500
Aral Aral SuperTronic Longlife III SAE 5W-30 50400/50700
Aral Aral Tronic 431 SAE 5W-40 50200/50500/50501
Armorine Couguar SAE 5W-40 50200/50500/50501
Astris Astris Matro L-3 SAE 5W-30 50400/50700
Auto-Teile-Ring Cartechnic Motorenöl SAE 5W-40 50200/50500
Auto-Teile-Ring Cartechnic Motorenöl Longlife III SAE 5W-30 50400/50700
Auto-Teile-Ring Cartechnic Motorenöl MS SAE 5W-30 50200/50500
Avia Avia Synth SAE 5W-40 50200/50500
Avia Avia Synth Longlife III SAE 5W-30 50400/50700
Beijing Tongy i Petroleum Xin Gai Nian SAE 5W-40 50200/50500
Blu Lubricants Inc Blu Synthetic SAE 5W-30 50200/50500/50501
BP BP EuroSpirit SAE 5W-40 50200/50500
BP BP Prof essional EURO Plus SAE 5W-40 50200/50500
BP BP Visco 5000 SAE 5W-40 50200/50500
BP BP Visco 5000 C SAE 5W-40 50200/50500/50501
BP BP Visco 7000 SAE 0W-40 50200/50500
BP BP Visco 7000 Longlife III SAE 5W-30 50400/50700
BP BP Visco 7000 Sport SAE 5W-40 50200/50500
BP BP Visco 7000 Turbo Diesel SAE 0W-40 50200/50500
BP BP Visco 7000 Turbo Diesel Sport SAE 5W-40 50200/50500
BP BP Visco 7000M SAE 0W-30 50200/50500
BP BP Visco Special V SAE 5W-40 50000/50500/50501
BP BP Visco Special V SAE 5W-40 50200/50500/50501
BP Meister-Öl Leichtlauf -Motorenöl SAE 10W-40 50200/50500
BP Meister-Öl Leichtlauf -Motorenöl SAE 5W-40 50200/50500
Bucher AG MOTOREX PROFILE V-XL SAE 5W/40 SAE 5W-40 50200/50500/50501
Bucher AG MOTOREX Select LA-X SAE 5W-30 50200/50500/50501
Bucher AG MOTOREX Select SP-X SAE 10W/40 SAE 10W-40 50200/50500
Bucher AG MOTOREX Select SP-X SAE 5W/30 SAE 5W-30 50200/50500
Caltex Caltex Havoline Ultra V SAE 5W-30 50400/50700
Carat ad-Diesel PD Oil SAE 5W-40 50200/50500/50501
Carat ad-High Tech Longlife III SAE 5W-30 50400/50700
Carat ad-Synt Oil SAE 5W-40 50200/50500
Cartechnic CARTECHNIC Motorenöl Pumpe- SAE 5W-40 50000/50500/50501
Castrol Adamol Multitop PDI SAE 5W-40 50200/50500/50501​
VW Oil Standards​
Castrol Castrol Edge SAE 0W-30 50200/50500
Castrol Castrol Edge SAE 0W-40 50200/50500
Castrol Castrol Edge SAE 5W-40 50200/50500
Castrol Castrol Edge SAE 5W-30 50400/50700
Castrol Castrol Edge Formula RS SAE 0W-40 50200/50500
Castrol Castrol Edge Sport SAE 0W-30 50200/50500
Castrol Castrol Edge Turbo Diesel SAE 5W-40 50200/50500/50501
Castrol Castrol Formula SLX SAE 0W-30 50200/50500
Castrol Castrol Formula SLX Long Tec Turbo Diesel SAE 0W-30 50200/50500
Castrol Castrol Formula SLX Professional Powerflow SAE 0W-30 50200/50500
Castrol Castrol GTX 9 Magnatec SAE 5W-30 50200/50500
Castrol Castrol GTX Magnatec SAE 5W-30 50200/50500/50501
Castrol Castrol GTX Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec C3 SAE 5W-30 50200/50500
Castrol Castrol Magnatec C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Diesel B4 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Diesel B4 SAE 5W-40 50200/50500/50501
Castrol Castrol Magnatec Diesel C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-30 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-40 50200/50500
Castrol Castrol Magnatec Professional C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Professional SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Professional SAE 5W-40 50200/50500/50501
Castrol Castrol SLX SAE 0W-30 50200/50500
Castrol Castrol SLX 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Longtec SAE 0W-30 50200/50500
Castrol Castrol SLX Professional SAE 5W-30 50200/50500
Castrol Castrol SLX Professional SAE 5W-40 50200/50500
Castrol Castrol SLX Professional 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Professional B4 SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional C3 SAE 5W-30 50200/50500
Castrol Castrol SLX Professional Diesel SAE 5W-30 50200/50500
Castrol Castrol SLX Professional LL03 SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Longlife III SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Longtec SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Longtec SAE 0W-40 50200/50500
Castrol Castrol SLX Professional OE SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional Powerflow SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Powerflow C3 SAE 0W-30 50200/50500
Castrol Castrol SLX Professional Powerflow Longlife SAE 5W-30 50400/50700
Castrol Castrol SLX Professional VW SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Turbo-Diesel SAE 0W-30 50200/50500
Castrol Castrol Syntec SAE 5W-40 50200/50500
Castrol Castrol Syntec 0W-30 European Formula SAE 0W-30 50200/50500
Castrol Castrol Syntec European Formula SAE 0W-30 50200/50500
Castrol Castrol TXT 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol TXT 507 00 SAE 5W-30 50400/50700
Castrol Castrol TXT Softec Plus SL SAE 5W-30 50200/50500
Cepsa Cepsa Star Mega Synthetic SAE 0W-30 50200/50500
Cepsa Cepsa Star Mega Synthetic SAE 5W-40 50200/50500
Cepsa Cepsa Star TDI Sy nt SAE 5W-40 50200/50500/50501
Chevron Caltex Havoline Fully Synthetic SAE 5W-40 50200/50500
Chevron Havoline Synthetic DS SAE 0W-30 50200/50500
Chevron Havoline Ultra SAE 5W-40 50200/50500
Chevron Havoline Ultra S SAE 5W-30 50200/50500
Chevron Havoline Ultra S SAE 5W-40 50200/50500
Chevron Havoline Ultra S SAE 5W-40 50200/50500/50501
Chevron Havoline Ultra V SAE 5W-30 50400/50700
Cyclon Hellas Cyclon F1 Racing SAE 5W-40 50200/50500
De Oliebron TOR Extendo SAE 5W-30 50400/50700
De Oliebron TOR Specialsynth SAE 5W-40 50501
Delek Delkol Motorsynth FE SAE 5W-30 50200/50500
Delek Delkol Motorsynth TDI SAE 5W-40 50200/50500/50501
Denicol Denicol Pro Syn 4 SAE 5W-40 50500/50501
Denicol Denicol Syn Extra Long Life III SAE 5W-30 50400/50700
Duckhams Duckhams QS Premium MO SAE 5W-40 50200/50500
Elf Elf Excellium SAE 0W-30 50200/50500
Elf Elf Excellium C3 SAE 5W-30 50200/50500/50501
Elf Elf Excellium DID SAE 5W-30 50200/50500/50501
Elf Elf Excellium DID SAE 5W-40 50200/50500/50501
Elf Elf Excellium DID SAE 5W-40 50500/50501
Elf Elf Excellium Full tech SAE 0W-30 50200/50500
Elf Elf Solaris LSX SAE 5W-30 50200/50500/50501
Engen Petroleum Engen Formula 505.01 SAE 5W-40 50200/50500/50501
Engen Petroleum Engen Xtreme SAE 5W-40 50200/50500
ENI R&M Division Agip Formula Prestige SAE 5W-40 50200/50500/50501
Enoc Protec X-treme SAE 5W-40 50200/50500
Esso Esso 505 01 SAE 5W-30 50200/50500/50501
Esso Esso Megatron SAE 5W-40 50200/50500
Esso Esso Ultron SAE 5W-40 50200/50500
Esso Esso Ultron Turbo Diesel SAE 5W-40 50200/50500
Esso Motor Oil Plus SAE 5W-40 50200/50500
Esso Tecar Leichtlaufmotorenoel SAE 5W-40 50200/50500
Esso Tecar Motorenoel 505 01 SAE 5W-30 50200/50500/50501
Esso Tecar Supersyn SAE 5W-40 50200/50500
Eurol Eurol Super Lite SAE 5W-40 50200/50500
Eurol Eurol Turbo DI SAE 5W-40 50200/50500/50501
Eurol XADO SL/CF SAE 5W-40 50200/50500
Fina Fina Delta 505.01 SAE 5W-40 50500/50501
Fina Fina First 500 SAE 5W-30 50200/50500/50501
Fina Fina First 600 SAE 0W-30 50200/50500
FL Selenia Aktual Fully Synth SAE 5W-40 50200/50500
FL Selenia Pulsar Progress SAE 5W-40 50500/50501
FL Selenia Selenia Benzina Multi Valves Generation SAE 5W-40 50200/50500
FL Selenia Selenia Diesel Common Rail Generation SAE 5W-40 50200/50500
FL Selenia Selenia DIGITECH SAE 0W-30 50200/50500
FL Selenia Selenia K SAE 5W-40 50200/50500
FL Selenia Selenia K Pure Energy SAE 5W-40 50200/50500/50501
FL Selenia Selenia Multipower C3 SAE 5W-30 50200/50500/50501
FL Selenia Selenia Performer SAE 5W-40 50500/50501
FL Selenia Selenia WR SAE 5W-40 50200/50500
Fuchs Fuchs TITAN GT1 Longlife III SAE 5W-30 50400/50700
Fuchs Fuchs TITAN GT1 PRO C-3 SAE 5W-30 50400/50700
Fuchs Fuchs TITAN Supersyn SAE 0W-30 50200/50500
Fuchs Fuchs TITAN Supersyn SAE 5W-30 50200/50500
Fuchs Fuchs TITAN Supersyn SAE 5W-40 50200/50500
Fuchs Labo RC SAE 0W-30 50200/50500
Fuchs Labo Syntha High Tech Synthese SAE 5W-40 50500/50501
Fuchs TITAN Formel MC SAE 5W-40 50200/50500
Fuchs Titan GT1 SAE 5W-30 50200/50500
Fuchs TITAN Supersyn LONGLIFE SAE 5W-30 50200/50500
Fuchs TITAN Supersyn PLUS SAE 5W-40 50200/50500/50501
Galp energia Galp Energy Plus SAE 5W-40 50200/50500
Galp energia Galp Energy Premium Plus SAE 10W-40 50200/50500
Galp energia Galp Energy SP SAE 5W-40 50200/50500
Galp energia Galp Energy Ultra LS SAE 5W-40 50200/50500
Galp energia Galp Formula 1 Plus SAE 5W-40 50200/50500
Galp energia Galp Formula 505 SAE 5W-40 50200/50500/50501
Galp energia Galp Formula 505 SAE 5W-40 50500/50501
Galp energia Galp Formula TD Plus SAE 5W-40 50200/50500
Galp energia Galp Formula XLD SAE 5W-40 50200/50500
Gamaparts GAMAPARTS Super LL SAE 10W-40 50200/50500
GEMA Formula SAE 10W-40 50200/50500
GEMA Formula S SAE 5W-40 50200/50500
Ginouves York 742 SAE 5W-40 50500/50501
Ginouves York 848 SAE 5W-40 50200/50500/50501
Ginouves York 940 SAE 5W-30 50400/50700
Ginouves York 948 SAE 5W-30 50200/50500
GMC Oil GML Oil Eternity TDI SAE 5W-40 50500/50501
Gulf Gulf Formula GX SAE 5W-30 50200/50500
Gulf Oil Gulf Formula G SAE 5W-30 50200/50500
Gulf Oil Gulf Formula G SAE 5W-40 50200/50500
Gulf Oil Gulf Formula GVX SAE 5W-30 50400/50700
Gulf Oil Gulf Formula ULE SAE 5W-30 50200/50500/50501
Gulf Oil Gulf Formular G SAE 0W-30 50200/50500
Gulf Oil Gulf TEC Plus SAE 5W-40 50500/50501
Gulf Oil Gulf Ultrasynth SAE 10W-40 50200/50500
Igol Igol Profive 505.01 SAE 5W-40 50200/50500/50501
Igol Igol Profive Gold SAE 5W-40 50200/50500/50501
Igol Igol Profive Silver SAE 5W-30 50200/50500/50501
Igol Process 505.01 SAE 5W-40 50200/50500/50501
Igol Process Compact M SAE 5W-30 50200/50500
INA INA Delta Sint SAE 10W-40 50200/50500
INA INA Millennium SAE 5W-40 50200/50500
Iranol Iranol 30,000 SAE 5W-40 50200/50500
Jet Jet Top Level SAE 0W-30 50200/50500
Kendall Motor Oil Kendall GT-1 Full Synthetic Motor Oil SAE 5W-40 50200/50500
Kroon-Oil Helar SP LL03 SAE 5W-30 50400/50700
Kuttenkeuler Sorotec Pdi SAE 5W-40 50200/50500/50501
Kuwait Petroleum Q8 Formula Excel SAE 5W-40 50200/50500
Kuwait Petroleum Q8 Formula V Long Life SAE 5W-30 50400/50700
Kuwait Petroleum Q8 Motoroil 505 01 SAE 5W-40 50500/50501
Liqui Moly Liqui Moly Diesel High Tech SAE 5W-40 50000/50500/50501
Liqui Moly Liqui Moly Leichlauf HC 7 SAE 5W-40 50200/50500
Liqui Moly Liqui Moly Leichtlauf Special LL SAE 5W-30 50200/50500
Liqui Moly Liqui Moly Longtime High Tech SAE 5W-30 50200/50500/50501
Liqui Moly Liqui Moly Nachfüllöl SAE 5W-40 50500/50501
Liqui Moly Liqui Moly Pro-Engine M 300 SAE 5W-30 50200/50500
Liqui Moly Liqui Moly Pro-Engine M 400 SAE 5W-40 50200/50500/50501
Liqui Moly Liqui Moly Pro-Engine M 500 SAE 5W-30 50200/50500/50501
Liqui Moly Liqui Moly Pro-Engine M 600 SAE 5W-30 50400/50700
Liqui Moly Liqui Moly Profi Premium SAE 5W-40 50200/50500
Liqui Moly Liqui Moly Synthoil Longtime SAE 0W-30 50200/50500
Liqui Moly Liqui Moly Top Tec 4100 SAE 5W-40 50200/50500/50501
Liqui Moly Liqui Moly Top Tec 4200 SAE 5W-30 50400/50700
Longpan Petrochemical Sonic 9000 SAE 5W-40 50200/50500
Lotos Lotos Economic SAE 5W-30 50200/50500
Lotos Lotos Economic SL/CF SAE 5W-30 50200/50500
Lotos Lotos Syntetic SL/SJ/CF/CD SAE 5W-40 50200/50500
Lotos Lotos Traffic SAE 5W-40 50200/50500
Lotos Lotos Traffic Diesel 505.01 SAE 5W-40 50200/50500/50501
Lotos Lotos Traffic Thermal Control SL/CF SAE 5W-40 50200/50500
Lotos Lotos Traffic Turbodiesel CF SAE 5W-40 50200/50500
Lukoil Lukoil Synthetic SAE 5W-40 50200/50500
Lukoil Lukoil-Synthetic SAE 5W-40 50200/50500
Meguin megol Motorenoel Compatible SAE 5W-30 50400/50700
Meguin megol Motorenoel Low Emission SAE 5W-40 50200/50500/50501
Meguin megol Motorenoel New Generation SAE 5W-30 50200/50500/50501
Meguin megol Motorenoel Power Synt SAE 10W-40 50200/50500
Meguin megol Motorenoel Super Leichtlauf Multisynth SAE SAE 0W-30 50200/50500
Meguin megol Motorenoel Super Leichtlauf Technology SAE 5W-40 50500/50501
Meguin megol Motorenoel Ultra Performance Longlife SAE 5W-40 50200/50500
Meguin megol Motorenoil Quality SAE 5W-30 50200/50500
Meguin Meister-Öl Super Leichtlauf -Motorenöl SAE 5W-40 50200/50500
Meguin Motorenoel Ultra Performance Longlife SAE 5W-40 50200/50500
Millers Oils Millers XF Longlife SAE 5W-30 50400/50700
Minerva Minerva TSV SAE 5W-30 50400/50700
Mobil Mobil 1 SAE 0W-40 50200/50500
Mobil Mobil 1 SAE 5W-40 50200/50500
Mobil Mobil 1 Arctic SAE 0W-40 50200/50500
Mobil Mobil 1 ESP Formula SAE 5W-30 50400/50700
Mobil Mobil 1 Formula C SAE 0W-40 50200/50500
Mobil Mobil 1 New Life SAE 0W-40 50200/50500
Mobil Mobil 1 New Life Turbo Diesel SAE 0W-40 50200/50500
Mobil Mobil 1 Turbo Diesel SAE 0W-40 50200/50500
Mobil Mobil 1 Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Formula X2 SAE 5W-40 50200/50500
Mobil Mobil SHC Formula V SAE 5W-30 50400/50700
Mobil Mobil Special X SAE 5W-40 50200/50500
Mobil Mobil Super 3000 Formula V SAE 5W-30 50400/50700
Mobil Mobil Super 3000 X1 SAE 5W-40 50200/50500
Mobil Mobil Super 3000 X2 SAE 5W-40 50200/50500
Mobil Mobil Super 3000 X2 Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Synt S SAE 5W-40 50200/50500
Mobil Mobil Synt S ESP SAE 5W-30 50200/50500
Mobil Mobil Synt S Turbo Diesel SAE 5W-40 50200/50500
Mobil Mobil Syst S Special V SAE 5W-30 50200/50500/50501
Mobil Tecar 50501 SAE 5W-30 50200/50500/50501
Modrica Optima Eco SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Gold SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Gold Longlife SAE 5W-30 50400/50700
MOL MOL Dynamic Max SAE 10W-40 50200/50500
MOL MOL Dynamic Prima SAE 5W-40 50200/50500/50501
Morris Lubricants Morris Multilife V-MAX SAE 5W-30 50400/50700
Motul Motul 6100 Synergie + SAE 10W-40 50200/50500
Motul Motul 8100 X-cess SAE 5W-40 50200/50500
Motul Motul 8100 X-clean SAE 5W-40 50200/50500
Motul Motul 8100 X-clean SAE 5W-40 50200/50500/50501
Motul Motul 8100 X-lite SAE 0W-30 50200/50500
Motul Motul 8100 X-max SAE 5W-30 50200/50500
Motul Motul 8100 X-max SAE 5W-40 50200/50500
Motul Motul H-Tech Multi Standard SAE 5W-40 50200/50500
Motul Motul Specific 505 01 SAE 5W-40 50200/50500/50501
Motul Motul Specific 505 01 SAE 5W-40 50500/50501
Motul Motul Specific 505 01 502 00 505 01 SAE 5W-40 50200/50500/50501
Motul Motul Synergie SAE 5W-40 50200/50500
MRD Motor Gold Highline SAE 0W-30 50200/50500
MRD Motor Gold Supertec SAE 5W-40 50200/50500
MRD Motor Gold Supertec PD SAE 5W-40 50500/50501
Neste Oil Neste City Pro SAE 5W-40 50200/50500
NIS Oil Refinery Beograd Galax Sint 502 SAE 10W-40 50200/50500
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-30 50200/50500/50501
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-40 50200/50500/50501
Northland Synergy Synthetic EuroSyn SAE 5W-40 50200/50500
Oel-Brack Midland Synova SAE 5W-40 50200/50500/50501
Oel-Brack Midland Synqron SAE 5W-40 50200/50500
Oest OEST Gigant LS Plus SAE 5W-30 50200/50500/50501
Ölwerke Julius Schindler Econo Veritas XL-HC SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas Longlife III SAE 5W-30 50400/50700
Ölwerke Julius Schindler OJS Econo-Veritas OM Extra SAE 0W-30 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas XL-HC SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Econo-Veritas XV SAE 5W-40 50200/50500/50501
Ölwerke Julius Schindler OJS Engine Oil SAE 5W-40 50200/50500
Ölwerke Julius Schindler OJS Meister-Öl Premium-Motorenöl SAE 0W-40 50200/50500
Ölwerke Julius Schindler OJS Platinum Vollsynthese SAE 0W-40 50200/50500
Ölwerke Julius Schindler OJS Veritas Syntolube SAE 0W-40 50200/50500
OMV OMV BIXXOL extra SAE 5W-40 50200/50500
OMV OMV BIXXOL extra Diesel SAE 10W-40 50200/50500
OMV OMV BIXXOL premium SAE 5W-40 50200/50500
OMV OMV BIXXOL premium Diesel SAE 5W-40 50200/50500
OMV OMV BIXXOL special C3 SAE 5W-30 50200/50500/50501
OMV OMV BIXXOL special G SAE 5W-30 50200/50500
OMV OMV BIXXOL special V7 SAE 5W-30 50400/50700
OMV OMV control light SAE 10W-40 50200/50500
OMV OMV eco extra SAE 5W-30 50400/50700
OMV OMV syncom SAE 5W-40 50200/50500
OMV OMV syncom diesel SAE 5W-40 50500/50501
Opet Opet OXT Formula V 507 SAE 5W-30 50400/50700
Orlen Oil Orlen Platinum Vollsy nthese SAE 0W-40 50200/50500
Orlen Oil Plantinum Synthetic SM/SL/CF SAE 5W-40 50200/50500
Orlen Oil Platinum MaxEnergy Euro 4 SAE 5W-30 50200/50500
Orlen Oil PLATINUM MAXENERGY EURO4 SAE 5W-30 50200/50500
Panolin Panolin Avanis SV-X SAE 5W-30 50400/50700
Panolin Panolin Daytona SAE 5W-40 50000/50500/50501
Panolin Panolin Daytona SAE 5W-40 50500/50501
Paramo Mogul Extreme SAE 5W-40 50200/50500
Paramo Mogul Racing S Pro SAE 5W-40 50500/50501
Paz Lubricants & Chemicals Ltd Top Paz SAE 5W-40 50200/50500/50501
Pennzoil Pennzoil Platinum European Formula SAE 5W-40 50200/50500
Pennzoil Pennzoil Platinum European Formula Ultra SAE 5W-30 50200/50500
Pennzoil Pennzoil Platinum European Ultra Diesel SAE 5W-30 50200/50500/50501
Pennzoil Pennzoil Platinum Low SAPS SAE 5W-30 50200/50500/50501
Pennzoil Pennzoil Platinum VX SAE 5W-30 50400/50700
Pennzoil Pennzoil Synthetic European Formula SAE 5W-40 50200/50500
Penrite Oil ENVIRO + SAE 5W-30 50400/50700
Pentosin Pento High Performance SAE 5W-30 50200/50500
Pentosin Pento High Performance SAE 5W-40 50200/50500
Pentosin Pento High Performance II SAE 5W-40 50200/50500/50501
Pentosin Pento Super Performance III SAE 5W-30 50400/50700
Pentosin Pentospeed VS* SAE 0W-30 50200/50500
Pentosin Pentosynth HC SAE 5W-40 50200/50500/50501
Petro China KUNLUN Tianrun SAE 5W-40 50200/50500
Petro China Kunlun Tianrun SAE 5W-40 50200/50500/50501
Petro China Kunlun Tianyuan SM SAE 5W-40 50200/50500/50501
Petrol Petrol 505.01 5W-40 SAE 5W-40 50500/50501
Petrol Of isi PO Maxima SAE 5W-40 50200/50500
Petrol Of isi PO Maxima Diesel SAE 5W-40 50200/50500
Petronas Petronas Syntium 3000 SAE 5W-40 50200/50500
Petronas Petronas Syntium 5000 AV SAE 5W-30 50400/50700
Poweroil High-Tech-Schmierstoff Poweroil High-Tech-Schmierstoffevollsynth. SAE 0W-40 50200/50500
Poweroil High-Tech-Schmierstoff Poweroil High-Tech-Schmierstoffe Longlife SAE 5W-30 50400/50700
Prista Oil Prista Ultra SAE 5W-40 50200/50500
Prof i-Tech Prof i-Car Synth Tech XT SAE 5W-40 50200/50500
PTT Public Company Limited Limited Performa Euro Syn SAE 5W-40 50200/50500/50501
PTT Public Company Limited Performa Euro Syn SAE 5W-40 50200/50500/50501
Quaker State Q Diesel Plus SAE 5W-30 50400/50700
Quaker State Q European Engine VX SAE 5W-30 50400/50700
Quaker State Quaker State Synquest SAE 5W-40 50200/50500
Quaker State Quaker State Synquest Low SAPS SAE 5W-30 50200/50500/50501
Quantum Quantum Longlife III SAE 5W-30 50400/50700
Quantum Quantum PD Diesel SAE 5W-40 50200/50500/50501
Quantum Quantum Synta ED SAE 0W-30 50200/50500
Quantum Quantum Synta Gold SAE 5W-40 50200/50500
Rafinerija Modrica Galax Racing SAE 5W-40 50200/50500
Rafinerija Modrica Optima 505 01 SAE 5W-40 50500/50501
Ravensberger Schmierstoffvertrieb Ravenol Super Synthetic SSO SAE 0W-30 50200/50500
Ravensberger Schmierstoffvertrieb Ravenol VPD SAE 5W-40 50200/50500/50501
Ravensberger Schmierstoffvertrieb Reratrvieebnol Hydrocrack Synth. HCS SAE 5W-40 50200/50500
Ravensberger Schmierstoffvertrieb Reratrvieebnol VSI SAE 5W-40 50200/50500
real real,- Quality GPD SAE 5W-40 50200/50500/50501
real real,- Quality GSL SAE 5W-30 50400/50700
real real,- Quality GSR SAE 5W-30 50200/50500
Redoil Italia Challoils Ultrasynt SAE 5W-40 50200/50500/50501
Repsol Repsol Elaion Full Performance SM SAE 5W-40 50200/50500
Repsol Repsol Elite 50501 TDI SAE 5W-40 50200/50500/50501
Repsol Repsol Elite 50501 TDI SAE 5W-40 50500/50501
Repsol Repsol Elite Competicion SAE 5W-40 50200/50500
Repsol Repsol Elite Cosmos SAE 0W-40 50200/50500
Repsol Repsol Elite Evolution SAE 5W-40 50200/50500
Repsol Repsol Elite Multivalvulas SAE 10W-40 50200/50500
Rothen Oil Rothen Extrasynth SAE 5W-30 50200/50500/50501
Rowe Hightec Synth RS 5W-40i SAE 5W-40 50200/50500
Rowe Rowe HIGHTEC ECOSYNT Longlife III SAE 5W-30 50400/50700
Rowe Rowe Synt - HC SAE 5W-40 50200/50500
Rowe Rowe Synt PD SAE 5W-40 50200/50500/50501
Rowe Rowe Synt RS DLS SAE 5W-30 50200/50500/50501
Rowe Rowe Synt RS HC-FE SAE 5W-30 50200/50500
SCT Mannol Extreme SAE 5W-40 50200/50500
Seventy -Six Lubricants 76 Pure Synthetic Motor Oil SAE 5W-40 50200/50500
Shanghai Lizhong LiZhong No.1 SAE 5W-30 50400/50700
Shanghai Lizhong LUHU SAE 5W-40 50200/50500/50501
Shanghai Tempo Tempo 8000-1A SAE 5W-40 50200/50500
Shanghai Tempo Petrochem Tempo 8000-1C SAE 5W-40 50200/50500
Shell Formula Shell Ultra AB SAE 5W-30 50200/50500
Shell PKW Motorenöl SAE 5W-40 50200/50500
Shell Q Diesel Plus SAE 5W-40 50200/50500/50501
Shell Q European Engine Ultra SAE 5W-30 50200/50500
Shell Q European Engine Ultra SAE 5W-40 50200/50500
Shell Q European Engine Ultra Diesel SAE 5W-30 50200/50500/50501
Shell Q Horsepower Full Synthetic SAE 5W-40 50200/50500
Shell Shell Helix Diesel HX7 C SAE 5W-40 50200/50500
Shell Shell Helix Diesel Plus SAE 5W-30 50200/50500
Shell Shell Helix Diesel Plus SAE 5W-40 50200/50500
Shell Shell Helix Diesel Plus VA SAE 5W-30 50200/50500/50501
Shell Shell Helix Diesel Plus VA SAE 5W-40 50200/50500/50501
Shell Shell Helix Diesel Ultra SAE 0W-40 50200/50500
Shell Shell Helix Diesel Ultra SAE 5W-30 50200/50500
Shell Shell Helix Diesel Ultra SAE 5W-40 50200/50500
Shell Shell Helix Diesel Ultra E SAE 5W-30 50200/50500
Shell Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700
Shell Shell Helix Diesel Ultra VA SAE 5W-30 50200/50500/50501
Shell Shell Helix HX7 SAE 5W-30 50200/50500
Shell Shell Helix HX7 SAE 5W-40 50200/50500
Shell Shell Helix HX7 C SAE 5W-40 50200/50500
Shell Shell Helix Plus SAE 10W-40 50200/50500
Shell Shell Helix Plus SAE 5W-30 50200/50500
Shell Shell Helix Plus SAE 5W-40 50200/50500
Shell Shell Helix Plus AR SAE 10W-40 50200/50500
Shell Shell Helix Plus Extra SAE 5W-40 50200/50500
Shell Shell Helix Plus S SAE 5W-30 50200/50500
Shell Shell Helix Plus S SAE 5W-40 50200/50500
Shell Shell Helix Plus SM SAE 5W-30 50200/50500
Shell Shell Helix Plus SM SAE 5W-40 50200/50500
Shell Shell Helix Plus VB SAE 10W-40 50200/50500
Shell Shell Helix Premium SAE 5W-40 50200/50500
Shell Shell Helix Ultec SAE 0W-40 50200/50500
Shell Shell Helix Ultra SAE 0W-40 50200/50500
Shell Shell Helix Ultra SAE 5W-30 50200/50500
Shell Shell Helix Ultra SAE 5W-40 50200/50500
Shell Shell Helix Ultra AM SAE 5W-30 50200/50500
Shell Shell Helix Ultra AM SAE 5W-40 50200/50500
Shell Shell Helix Ultra AV-L SAE 5W-30 50400/50700
Shell Shell Helix Ultra AX SAE 5W-30 50200/50500/50501
Shell Shell Helix Ultra C SAE 0W-40 50200/50500
Shell Shell Helix Ultra E SAE 5W-30 50200/50500
Shell Shell Helix Ultra Extra SAE 5W-30 50400/50700
Shell Shell Helix Ultra Extra Polar SAE 0W-40 50200/50500
Shell Shell Helix Ultra VX SAE 5W-30 50400/50700
SIG Car Jack GPD SAE 5W-40 50200/50500/50501
Singapore Petroleum SPC Syn Ace API SM/CF SAE 5W-40 50200/50500
Sinopec Blue Spirit SAE 5W-40 50500/50501
Sinopec Great Wall Ultra Gold V5457 SAE 5W-30 50400/50700
Sinopec Polar Star SAE 5W-40 50200/50500
Sinopec Polar Star III SAE 5W-40 50200/50500/50501
Sinopec Ultra Gold SAE 5W-40 50200/50500/50501
SK energy ZIC RV SAE 5W-30 50200/50500
SK energy ZIC XQ SAE 5W-40 50200/50500
SK energy ZIC XQ RV SAE 5W-40 50200/50500
S-Oil Corporation SSU EURO XT SAE 5W-30 50200/50500
S-Oil Corporation SSU EURO XT SAE 5W-40 50200/50500
Sonol Sonol Synt 502.00 SAE 5W-40 50200/50500
Sonol Sonol Synt 505.01 SAE 5W-40 50500/50501
Startol RASANTA SPECIALSYNT SAE 5W-40 50000/50500/50501
Startol Startol Rasanta Specialsynth Pdi SAE 5W-40 50200/50500/50501
Startol Startol Transit Diplomat Longlife III SAE 5W-30 50400/50700
Statoil PRO Synthetic C SAE 5W-40 50200/50500/50501
Statoil Statoil LazerWay SAE 5W-40 50200/50500
Statoil Statoil LazerWay C SAE 5W-40 50000/50500/50501
Statoil Statoil LazerWay C SAE 5W-40 50200/50500
Statoil Statoil LazerWay LL SAE 5W-30 50400/50700
Statoil Statoil LazerWay TDI SAE 5W-40 50200/50500
Statoil Statoil PRO Synthetic SAE 5W-40 50200/50500
Sun Oil Sunoco Ultra semi-synthetic SAE 5W-40 50500/50501
Sunlight Sunlight Fully power F-1A SAE 5W-40 50200/50500
SWD Concep-Tech HDC SAE 5W-40 50200/50500
SWD Concep-Tech Synth. SAE 5W-40 50000/50500/50501
SWD Concep-Tech Synth. SAE 5W-40 50500/50501
SWD GECCO Motorenöl HC SAE 5W-40 50200/50500
SWD GECCO Motorenöl SY SAE 5W-40 50500/50501
SWD GECCO Motorenöl VZW SAE 5W-30 50400/50700
SWD swd PRIMUS DX SAE 5W-30 50200/50500/50501
SWD swd Primus HDC SAE 5W-40 50200/50500
SWD swd PRIMUS LLX SAE 5W-30 50400/50700
SWD swd Primus Synth. SAE 5W-40 50000/50500/50501
SWD swd Primus Synth. SAE 5W-40 50500/50501
TACTI Corporation Castle Euaro 502 SAE 5W-40 50200/50500
TACTI Corporation Castle Euaro 504 SAE 5W-30 50400/50700
Tamoil Tamoil SINT FUTURE EXTRA SAE 5W-40 50200/50500/50501
Tamoil Tamoil Sint Future Longlife III SAE 5W-30 50400/50700
Tamoil Tamoil Sint Future Power SAE 5W-30 50400/50700
Tamoil Tamoil SINT FUTURE RACING SAE 5W-40 50200/50500
Tecar Tecar Motorenoel SAE 5W-30 50400/50700
Tecar Tecar Motorenoel 504 00 / 507 00 SAE 5W-30 50400/50700
Tedex Tedex Synthetic Motor Oil SAE 5W-40 50200/50500/50501
Texaco Havoline 505.01 SAE 5W-40 50500/50501
TNK Lubricant LLC TNK Magnum Synthetic SAE 5W-40 50200/50500
TNK Lubricant LLC TNK Ultra SAE 5W-40 50200/50500
Total Gulf Formula Extreme SAE 0W-30 50200/50500
Total Gulf GDI Extra SAE 5W-40 50500/50501
Total Total Activa 9000 SAE 5W-40 50200/50500
Total Total Activa Diesel 9000 SAE 5W-40 50200/50500
Total Total Activa Energy 9000 SAE 0W-30 50200/50500
Total Total Quartz 505.01 SAE 5W-40 50500/50501
Total Total Quartz 9000 SAE 5W-40 50200/50500
Total Total Quartz 9000 Energy SAE 5W-40 50200/50500
Total Total Quartz Energy 9000 SAE 0W-30 50200/50500
Total Total Quartz INEO MC3 SAE 5W-30 50200/50500/50501
Unil Opal Opaljet 24 S SAE 5W-40 50200/50500
Unil Opal Opaljet Energy 3 SAE 5W-30 50400/50700
Unil Opal Opaljet Futura SAE 5W-40 50200/50500/50501
Unil Opal Opaljet Futura SAE 5W-30 50400/50700
United Oil United 1 Fully Synthetic SAE 5W-40 50200/50500
Valvoline Synpower MST SAE 5W-30 50200/50500/50501
Valvoline Synpower MST SAE 5W-40 50200/50500/50501
Valvoline Valvoline DuraBlend MXL SAE 5W-40 50200/50500
Valvoline Valvoline SynPower HST SAE 5W-40 50200/50500/50501
Valvoline Valvoline Synpower MST SAE 5W-30 50200/50500/50501
Valvoline Valvoline SynPower XL-III SAE 5W-30 50400/50700
VAPS Vapsoil 502 00 SAE 5W-40 50200/50500
VAPS VAPSOIL 505 01 SAE 5W-40 50000/50500/50501
VAPS Vapsoil 505 01 SAE 5W-30 50200/50500/50501
VAPS Vapsoil 505 01 SAE 5W-40 50200/50500/50501
VAPS VAPSOIL 507 00 SAE 5W-30 50400/50700
Vial Oil Consol Ultima SAE 5W-40 50200/50500
Volkswagen Mexico Audi, Seat, VW Aceite para Motor a Gasoline SAE 5W-40 50200/50500
Volkswagen Original Teile Volkswagen LongLife III SAE 5W-30 50400/50700
Volkswagen Original Teile ® Motorenoel G 052 167 A2 SAE 5W-40 50000/50500/50501
Volkswagen Original Teile ® Volkswagen Special plus SAE 5W-40 50200/50500/50501
Weco Weco TXI Sy ntolube SAE 5W-40 50200/50500
Westfalen AG Westfalen Gigatron SAE 0W-40 50200/50500
Westfalen AG Westfalen Mega Tron SAE 5W-40 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife SAE 5W-30 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth SAE 5W-40 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth alpha SAE 5W-30 50200/50500
Wintershall - SRS SchmierstoWf Wintershall ViVA 1 longlife topsynth alpha LA SAE 5W-30 50200/50500/50501
Wolf Startol Rasanta Specialsynth Pdi SAE 5W-40 50200/50500/50501
Wolf Wolf Masterlube Synflow DC SAE 5W-40 50200/50500
Wolf Wolf Masterlube Synflow LL III SAE 5W-30 50400/50700
Wolf Wolf Masterlube Synflow PI SAE 5W-40 50200/50500/50501
Würth Triathlon Endurance III SAE 5W-30 50400/50700
Würth Triathlon Formula LL SAE 5W-30 50200/50500
Würth Triathlon Performance SAE 5W-40 50200/50500/50501
Würth Triathlon Special PD SAE 5W-40 50200/50500/50501
Yacco Yacco VX 1000 SAE 5W-40 50200/50500
Yacco Yacco VX 1703 FAP SAE 5W-30 50200/50500/50501
Yacco Yacco VX 1703 FAP SAE 5W-40 50200/50500/50501
Yacco Yacco VX 505 SAE 5W-40 50500/50501
Yacco Yacco VX 600 SAE 5W-40 50200/50500
YPF YPF Elaion Full Perf ormance SM SAE 5W-40 50200/50500
Zeller+Gmelin Divinol Syntholight SAE 0W-40 50200/50500​
Zeller+Gmelin Divinol Syntholight SAE 5W-40 50200/50500
phlfly
Banned
N.VA
Passat SEL
Link
I checked in my local NAPA store and they have on stock 5 gal for 50 bucks, it's said on box 507.00
JSWTDI09
Las Vegas, Nevada
Why is 2005 breaking news in 2013
Will this site ever clean it self up
It was breaking news when this thread was started. This site does not "clean itself up". Actual people have to do any "cleaning" that is required. Thread titles do not get changed unless someone asks a moderator to do it. They have far to much to do to routinely go through thousands of threads to see if they need "cleaning". This (and other websites) are not self administered. All the moderators and administrators here are volunteers and this is not their full-time jobs. It is what it is - learn to live with it.
Have Fun!
Don
jimbag
FL
2013 Jetta TDI
Just curious, what happens if you run say regular Synpower 5w30 where 507 00 is required? I had a customer refuse to take my advice, and I'm wondering what's going to happen to his customer's 2011 Jetta TDI.
SilverGhost
Back in So Flo - St Lucie
I believe the 507.00 requirement is mainly low ash content. I would say a plugged DPF in the long term. How long depends on how much blow by and there fore how much oil reaches the DPF.
I would compare it to running regular leaded gas in a car with a catalytic converter.
Jason
quintman88
519 Winona Lakes East Stroudsburg, PA 18302
2009 VW Jetta TDI
What about AMSOIL European Synthetic 5w30 (AEL)
Hello everyone. My experience with AMsoil and Diesels has always been positive, and my sense is that their products outperform many of the products on the market in terms of wear and longevity. Amsoil has come out with a new product that specifically meet the 504/507 specification. Does anyone have any input on this oil. I just recently purchased a 2009 Jetta TDI with 156,000 on it. In a month I have 163,700. Not knowing or feeling comfortable when I bought the vehicle , I immediately changed the oil and put in Mobil 1 truck/Diesel 5-30. My last change, I contacted the dealer and of course they told me to use Castrol LL03, which I used on this oil change. What I notice in several hundred miles is that I now have a residual deposit above the exhaust on the bumper. I never had that with the Mobil 1. In any event, protection from wear and BTN is also important as well. In any event, I feel more comfortable with Amsoil products than even the Mobil 1. And I question if the Mobil 1 really meets the spec. Also, does the 2009 VW jetta have the particle filter and where is it and how is it maintained. Please advise and give me your thoughts and direction.
donDavide
Severna Park, Maryland USA
2003 Jetta ;2006 Golf; 2015 Jetta S
You need a 507.00 because your car does have a DPF, not M1 truck diesel. Check out ID parts, World Impex and you can get 507 from them, Total, Pentosyn, Castrol, Etc. if you like M1, check out AV Lube in Ohio, or keep you eyes open for coupons form Manny, Moe and Jack, I got 5 liters of M1 ESP 504/507 for $30, I could have gotten a filter too, but they had none for any of my vehicles.
MacBuckeye
North Carolina
2009 Jetta
How can a 504/507 grade oil be suitable for BOTH gasoline and diesel engines?
I'm looking to switch from Castrol LL03 to Mobil 1 ESP. In reading the Product Data sheet is says it is for both diesel and gasoline engines. My limited knowledge on engine oils would tell me a diesel engine would require a different type of oil than a gasoline engine.
Sorry if this has been discussed a zillion times.
tditom
san antonio & austin
504 is the gasser spec. They wanted an oil that can serve both applications. Probably a very robust oil because it is "overbuilt" for gasser apps due to needing to meet diesel app too.
Bob_Fout
Oil Wanker
Indiana
Truck diesel oils are almost always dual-purpose too, meets API SM or SN. Might not be the correct grade certainly not ILSAC, but they'll work for most fleet vehicles.
GD
Toronto
2011 Jetta TDI Highline DSG
So do I read this right no 5W40 for a 2011 TDI?
