iluvmytdi
It ain't gonna warm up till you GO! So GO GO GO!
Rules that apply for the life of the carHi
I was surprised to read these break in instructions in that it seems to suggest that for the life of the car you need to keep the revs above 2500 when cold and 3000 when warm. Have I read this right?
I drive at between 1500 to 2500 at all times without lugging it - I cant imagine going around at above 2500 and 3000. Since maximum torque is at 1900 rpm, wouldnt this be the point that gives maximum seating pressure on the rings regardless of what boost is applied by the turbo?![]()
I might have to change my habits!
Steven
I do.im not sure what DBW was trying to relay to us ...
Under Steady state driving on the highway with a VNTWHAT ABOUT THE RPM THAT YOU *MAINTAIN* ??!<font color="blue"> the shifts "points" are specific to when cold and when warm......so, @ 2500 "when cold" -shift- and @ 3000 "when warm"shift . I don't have to rev it hard to get to 3000. Shifting @ 3000 does not imply lots of go pedal, one can "take it easy", and shift at 3000 as well. </font> my .02![]()
By maintain I mean which you keep almost constant let's say during highway drives (constant = +/- 100 RPM)
From your last poist DBW it seems like the cruise is bad for a new engine because of low or no sustained boost, would using the cruise in hilly terrain (theoretically) not be bad then because of significantly varied throttle inputs? Is the steady RPM not the bad thing about the cruise, but instead the lack of boost?So why specifically is the cruise controll bad during the first 5000 miles?
-Jack
Do you think you could change the rpm limitation with vag-com?Keep in mind that this engine if it was allowed by the ECU could safely reve to around 7,000 rpm with not ill effects.
