So the brake system has just been properly bled, using VCDS, and the brake pedal when pumped gets tight like normal. When the car is on, the brake pedal seems normal, except when stopping... you have to jump on them quite a bit for the car to stop. Now I know this indicates a vacuum leak of some sort, and I have looked at the brake booster hose and compared the entire vacuum system to another TDI. I have started the car and wiggled the hose to see if i could hear or feel any sort of leak and nothing. I don't think it is my master cylinder as it was working prior. Is there anything you guys would recommend, or what parts I should take a closer look at? Thanks
