brake wear sensor on a TDI
messerchmidt
hi all, changed the brakes on my tdi with a first line aftermarket set. these did not have a sensor on the pads though. i disc the old sensor (as it was on my worn pads) and left the plug there. now the brake light turned
anything i can put on there to turn off the light? certain resistor or?
ymz
Between Toronto & Montreal
2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
You can use Vag-Com to disable the warning light, or you can just short the two connector wires and that should clear it...
Yuri.
PS: the vag-com routine is as follows (at least that's how it was on the older cars)
Select: INSTRUMENTS
Select: RECODE
NOTE: At this screen you'll see the instrument configuration setting. You will be making a change to the first (left two #) two digits of the software coding.
For examble the software coding is set to 07XXX.
To turn off the brake-pad wear sensor reduce the first 2 digits by one (1).
Change the software coding to 06xxx.
Save the change and you're done.
This will turn off the brake-pad wear sensor
K2 TDI
Syracuse NY
Which wheel is the brake wear indicator on?
My indicator just turned on yesterday, but the brakes were redone only a few months ago. I'd just like to disable the thing by shorting it or worst case getting someone to recode it.
biopete
Nashville, TN
A3 Jetta 1998, A4 Jetta 2001
I'd like to fix my wear sensor
My wear sensor came on. I checked my pads. My rears were way low and ready to change. I changed them (no sensor plug i could see in pads), and thanked my wear sensor. But it did not go out. I like it and want to fix it. The front pads are ok with about 1/4 of an inch of pad.
dabear95
Roseville, MI
2002 Golf GLS, Silver
The wear sensor only applies to the front pads and is, well, notorious for alarming the owner early.
Jason
ymz
Worse than that, I'm afraid...
It only applies to one of the four front pads... if there's a brake problem other than the thinning out of the inside left pad, the system leaves the driver clueless...
Brakes must be checked every time you rotate your tires.
Yuri.
BugBug
Minnesota
2001 Beetle TDI, 2005 New Beetle
Even though your outside brake pad shows a 1/4" the inside pad may be worn much further. The indicator pad (the one with the wire) is on the inside on the drivers side. Make sure the wire is properly plugged in and the wire is not broken.
biopete
Nashville, TN
Thanks. Wow. I guess I just had a lucky coincidence.
