Jonahphile
A while ago my glow plug light started blinking and the ESP and ABS lights came on as well. at the same time, someone mentioned that my brake lights were out. So, I naturally went to the fuse box and found that fuse number 13 was blown. My first thought was a bad brake light switch. Having read on this site, and on Passatworld.com that several people were having problems with their brake light switch, I replaced it. but, the fuse still blows! a
There is a wrecking yard close by so rather than try to chase down an electrical short, I thought I'd just get a replacement switch from the wrecking yard. I installed it and the problem was gone! at least I thought, it worked for one day and then the fuse blew again.
So, I've spent a couple days trying to track down the issue doing everything from taking out the taillight bulbs to removing some of the modules under the dash, thinking that if one of them may have a short--I still have a short and the fuse still blows.
Any thoughts?
All of the posts I read concerning brake light switch problems never mentioned whether the fuse for the brake lights would blow or not.
Any thoughts?
