M
mickey
Guest
The VW owners manuals mentions somewhere that you shouldn't use DOT 5 brake fluid. The Bentley manual goes into more detail. If you're like me, when you shop for that kind of thing you tend to buy the gnarliest, most expensive stuff you can find. I used to use high-temperature, silicon based DOT 5 brake fluid all the time for no other reason than it seemed like a cool idea. But here's a direct quote from Bentley regarding use of DOT 5 fluid in an ABS system:
"Do not use silicone-based brake fluids (DOT 5). This fluid is incompatible with the brake system and even the smallest trace can cause severe corrosion."
Wow. The point is well taken. Thought I'd share that with you all, since some of you might do the periodic brake fluid replacement yourselves. Use the exact fluid specified by VW.
-mickey
-mickey
