UhOh
OK, so I know that Bentley specifies 48 ft-lbs, and that everywhere else people seem to say the same, but...
I'm installing new carriers and have found that due to the thickness of these carriers the bolts do not engage them like the original carriers (bolt threads would actually extend past the bolt holes a bit, whereas with the new carriers they seem to be a good 1/3" shy of filling the bolt holes [keep in mind that the front part of the hole is not threaded]).
I was installing one carrier and got the top bolt torqued to 48 ft-lbs, but when doing the lower one I could feel that it was starting to give way. Talked to the parts vendor and it was suggested to use a lower torque. It's a bit frustrating in that I'm not seeing any accounting of this problem by anyone else. I'm considering going with 40 ft-lbs and using loctite (blue).
Did I get a defective carrier, or are replacement ones just not as capable of holding the factory torque? Maybe it's that longer bolts are needed?
This was pretty much a simple job and now it's just turned to crap. (so much for using all new parts!)
