mydeathbynapalm
So I've been dealing with a potential brake booster failure on my 2002 Golf.
I have replaced all the vacuum lines in the car, including the hard lined vacuum pump to booster. There has been no difference with those replacements. The white/black check valve appears to function fine as well.
Symptoms:
Brake pedal becomes hard(and seems to push back on my foot) after a few seconds of braking, and braking power diminishes to where I have to stomp on the pedal to stop.
I hear a hissing from within the driver's footwell when the brake pedal is pressed.
Short/abrupt stops are fine as the diminished braking comes after a few seconds of pressing the pedal. Brake fluid level is normal. Turbo boost seems to be functioning normally as well.
I haven't been driving the car day to day due to this issue. Is there a test to otherwise perform on the booster? Or are these signs pointing to a failed booster?(and I might as well dive into the repair)
Anyone in the immediate NoVA/DC area who has the pedal release tool? T10006a is the part number for the tool I think.
thanks.
Symptoms:
thanks.
