tongsli
I just want to share this in case it helps someone. I've been parking in an underground garage for 1 year now. It's great, but very humid(and warm) because it's below ground.
Over the past 6 months, I've noticed my interior lights no coming on when opening the car door. As I had already replaced the lock, I knew it wasn't the micro switch.
Also, when I wold start and drive the car, it would go away.
at the same time, I started getting a random ABS light associated with the Brake Pressure Switch being intermittent.
I am now convinced all my electrical issues are related to parking in such a humid environment. So I ended up replacing one of my two ABS/ESP sensors which helped. But I also replaced the ABS fuse and sprayed it with Deoxit. Fuse 9.
I also opened up the CCM and sprayed the circuit board.
Now I keep a damprid container under the passenger's side seat to try and combat the extra humidity and park the car on the upper levels. Lowest levels have standing water that doesn't drain.
I did spray the blade fuses on top of the battery.
Everything I've done has helped. Lights come on and no more random ABS light
