98JettaBioDiesel
COMPLETE CUSTOM BRAIDED OIL FEED LINE KIT
$79 complete includes USPS 1st Class to US destinations with tracking.
I've sole a dozen or so of these kits on EBAY (user Green1Eng search "Braided Turbo Feed Line Kit VW A3/B4 AHU/1Z Replaces Original 028145771BC")
all with positive feedback - mine's working great too!
For AHU and 1Z motors on Volkswagen B4 Passats and A3 Jetta TDIs
Replaces OEM Hard Feed Line 028145771BC and associated fittings
Jetta TDI MkIII (A3 body style - AHU engine)(1997-1999)
Passat TDI (B4 Passat with 1Z or AHU engine)(1996-1997)
NOTE TO BUYERS: This kit includes BOTH turbo fittings. If you know which fitting you need I offer a $10 discount (please specify fitting with offer). I will also refund $10 if you return the unused fitting within 1 month after receipt of the kit (you pay return postage). Please see below regarding turbo end fitting.
INCLUDES FOLLOWING:
Note that actual parts supplied may differ SLIGHTLY from photos due to minor differences between various suppliers. I will be happy to send you a photo of the exact parts in stock - just send me a message.
* Custom Length Braided Nylon Line (with plated steel swivel 4AN fittings)
* Turbo End Union Fitting plated steel (Warner/KKK and GARRETT turbo fittings included - see below)
* Oil Supply End M12x1.5 Banjo Fitting plated steel
* Crush Washers
* Cushioned P Clamp
* Protective Bushing
* Detailed installation instructions with photos, suggested tools, etc.
PLEASE READ ALL THE FOLLOWING INFORMATION CAREFULLY BEFORE ORDERING!
Turbo End Union Fitting Information: The A3/B4 TDI uses one of two different turbos which have different thread sizes at the oil feed line connection. The original equipment fitting is replaced with the supplied fitting, so if you are switching turbo types this kit will save you the additional cost of purchasing the alternate OEM union used with the hard line. This kit comes with BOTH fittings, but if you know what you need I will accept an offer $10 less than my selling price (specify fitting with offer), or you can return the unused fitting within one month for a $10 refund (you pay return shipping)
KKK TURBO (Borg Warner)= M12 x 1.5mm thread (new union replaces OEM 028145786)
GARRETT TURBO = M10 x 1 thread (new union replaces OEM 045115677A)
About the kit: I designed this kit for my 1998 Jetta TDI (AHU engine) after the hard line fitting at the turbo end developed a significant leak. I wanted a braided line setup, but wasn't satisfied that any I found were going to provide a correct and professional fit for the AHU/1Z engine - some others were designed for the newer engines and stated they could be also be supplied for AHU/1Z (but without details), did not have the correct end fittings to avoid interference, or were a generic type with various fittings of questionable quality (some aluminum) and tubing that was too long. I tried a few different hose lengths and fitting combinations before I was satisfied with the result. The hose in this kit is high quality stainless braided nylon with professionally crimped 4AN plated steel swivel (female) 4AN fittings on each end - straight on the oil supply end and 90 degree on the turbo end. The union and banjo fittings are high quality plated steel with correct straight threads to oil supply and turbo and male 4AN to the tube connection. These 4AN fittings do not have a small bore restriction found on some turbo fittings.
Warranty and Returns: I expect this kit will provide you (and me!) with many years of trouble free service when installed according to instructions. I will replace any defective parts for one year. Not responsible for any damage or other liability as a consequence of misuse or failure of any parts in this kit beyond replacement of any defective parts for up to one year. If you are not satisfied with this kit you may return it unused within two weeks for a refund (you pay the return shipping). You may return the unused turbo union fitting within four weeks for a $10 refund (you pay return shipping).
PLEASE SEND ME A MESSAGE FOR FURTHER INFORMATION OR QUESTIONS!
Mark
98JettaBioDiesel
INCLUDES FOLLOWING:
* Crush Washers
* Cushioned P Clamp
Mark
98JettaBioDiesel
