2000alhVW
The bottom 2 inches of both of my front windows are hazy/cloudy. I can't clean it up.
Hard to pick up in photos, but looks very grubby in person.
I originally assumed it had to do with a PO being a smoker, but I saw someone mention something about the plastics "ungassing"? Which would make sense as the window haze is right next to the plastic door cards.
Is there anything I can do about this? Thinking I might have to remove the glass and 'polish' up with some steel wool. Or is that a bad idea?
Also, pretty sure everything is original in the front end of my 2000 Golf w/160k. I'll just assume bushings are shot, and I'd much rather throw on a new control arm that already comes with bushings and a ball joint.
Are these control arms reversible, or mirrored?
When looking at bare CA, it only lists 'lower', but when looking at CA with LBJ, it says left or right.
Is it possible to flip CA over and bolt in the ball joint from the other side?
