german_cargo
I don't have any engine codes but I'm down on power under full throttle, and I hear a faint vacuum cleaner sound under light throttle right when I tip in that fades away if I stay in the throttle. However -- It doesn't make the vacuum cleaner sound when I rev it at idle, and the mechanic I took it to said there were no boost leaks that showed up with his smoke test and didn't think any more diagnosis was necessary without a trouble code present until he replaced the boost pipes from the intercooler up to the intake that had oil residue between the joints.
I've done the "dog collar" mod with a plump new O ring and replaced the weeping boost pipes from the intercooler up to the intake and it made no difference. Someone suggested the EGR pipe is cracked and to check for soot, but I don't see any soot anywhere. I noticed recently that sometimes it makes the "choo" sound when I let off the throttle and sometimes it doesn't under similar conditions. The vacuum cleaner noise is 100% consistent though.
What kind of boost leak or vacuum leak shows up under minimum throttle while driving but not while revving in the driveway???
