ken.fresno-tdi
- Joined
- Jan 3, 2006
- Location
- Fresno, CA
- TDI
- 95 Eurovan EVC camper with 98 AHU engine (VeganVan02); 01 Jetta ALH engine and parts - waiting for transplant into 97 Eurovan (VeganVan03);05 BEW Beetle
My 98 Jetta AHU install into a 95 Eurovan has been great with one exception. I keep occasionally getting a 0575 code (boost control difference) and going into limp mode, but only when accelerating moderately in 4th or 5th gear up an incline. In regular hard acceleration on flat road it *never* happens. I had the engine prior to the transplant and it ran fine, but I added some mods during the transplant. Since the transplant I've only put on about 5000 miles.
For the transplant into the Eurovan I did the following:
- K03/04 hybrid turbo from KermaTDI
-Kerma tuned chip
-Bosio injectors
as well as:
-replaced all vacuum and pressure hoses with viton
-new FMIC with 2" pipes and tubing; pressure tested at 20+ PSI and no leaks
-new N75 valve
-replaced 3" hose inside ECU
I'm stumped. The only thing I haven't actually done is check the actuator but the turbo only has 5000 miles on it and is just a year old, and I live in a very dry part of California, so rust is not an issue. Like I mentioned, it ONLY happens occasionally on moderate acceleration while going uphill. So, for example, I went up 5000 feet yesterday and I had to reset limp mode using my Scangauge II at least 10 times. Very annoying.
Here's a link to logged data in a CSV file from about 7 minutes of driving with group 003, 008, and 011. I added column Q which is specified minus actual MAP values. edit: (I think) the engine went into limp mode at 411 seconds, when the difference was 703.8. There were several times before that where it was in the 700s, and often in the 300-400 difference range.
What is 'normal' difference between requested and actual MAP? What else to check?
Thanks for any help you can give me!
Ken
-Kerma tuned chip
-Bosio injectors
as well as:
-new N75 valve
Ken
