There's a PDF of the Bentley manual out there. The file is "Bentley - Volkswagen Jetta, Golf, GTI MK4 Service Manual- 1999-2005 - OCR.pdf"
It's OCR'd and the quality is high, but it doesn't have any bookmarks. At almost 2,000 pages, it's a pain to navigate around.
I've generated a set of bookmarks for all of the chapter & section starts, and the Jetta TDI wiring diagrams. The bookmarks can be placed into the pdf using pdftk, which is available for windows and linux, and I assume mac.
EDIT: It appears that it's a bit of a pain to install PDFTK on a Mac. One solution is to use a linux virtual machine.
Here's the command line to insert the bookmarks...modify the filenames as needed:
EDIT: bookmarks file available on github
Sample bookmarksStore the following bookmark definitions in a file called "bookmarks.txt" to work with the command above. I made an Excel spreadsheet to generate this so it's easy to add more entries.
Code:
pdftk Bentley_VolkswagenJettaGolfGTI_MK4ServiceManual_1999-2005.pdf update_info bookmarks.txt output Bentley_VolkswagenJettaGolfGTI_MK4ServiceManual_1999-2005_Bookmarks.pdf
Sample bookmarks
Code:
BookmarkBegin
BookmarkTitle: ii ... Important Safety Notice
BookmarkLevel: 1
BookmarkPageNumber: 2
BookmarkBegin
BookmarkTitle: 97-878 ... No. 81/16 (Lanes 197 - 210)
BookmarkLevel: 3
BookmarkPageNumber: 1808
