I'm figuring this is no longer a problem, but you are correct on the bolt pattern. The offset, hmmm, IIRC a range from 35-45 is about correct. I wouldn't go less than 35 (the tire might start rubbing on the struts), and more than 45 will start to put undue stress on the wheel bearings. Unless you really need tires that wide.
