I picked up my 86 TD for $500 at an auction knowing it needed work but it ran and drove so... why not?
I'm now into it over $3000 which I don't mind. Mechanically it's getting better. Good suspension up front, replaced steering rack, tie rod assemblies, ball joints, replaced tranny, clutch cable, rear shocks, rear axle bushings rear brakes, front pads are good, the engine was recently rebuilt, glow plugs and relay are 6 mnths old. New winter tires, new summer tires.
The bad part is that the body is [censored]. The doors are ok but only 2 handles work properly. One is screwed to the door with wood scres and barely works, one is iffy. Door rust is minimal but the inner cards are mostly thrashed. The driver's power window works but the other 3 windows are held up by wood. /images/graemlins/blush.gif
The rockers have holes everywhere. They've been patched and coated well so they look ok but they wont last more than another year or two. The floor is in the same condition. Frame is rusty but seems ok.
Am I better off doing a half decent body job to tie this beater over for a few years or do you think I should be spending that money and more on a fresher body and transplant the goods? Neither is a really cheap option. Also consider I don't have a shop to do work in. I have to do what I can in the driveway and a motor swap is out of the question. It has to be done elsewhere and its not really cheap.
Have any of you done anything like replace or perform major surgery on these old unibodies? Body work is not my forte so I have no idea what it would cost to have holes cut out of the floor, new sheet metal welded in. Same with the rockers. The floor actually isn't bad at all. It's mostly all there and solid. Just the rockers and the first 8 inches in under the car needs most of the work.
I know without seeing it you can't be very precise. Just looking for opinions and any been-there done-that experience. I've got a $2000 budget if I go with getting a fresher body and swapping mechanicals. I'd want to stay under $1000 if I keep this body.
Thanks for your thoughts,
Blake
Blake
