This update is listed as being for ALL 2012 and 2013 vehicles with the RCD-510 except the Routan, Touareg, and Jetta Hybrid. It says so right on the TSB.Call your dealership before going in. For some reason, this update was not listed as available for my VIN. I'll try checking again in a week or so...
Then it applies to your vehicle.And I have a 2012 Jetta TDI with the RCD-510..
I haven't seen someone with a Blackberry in a while!FWIW it does it with my BB 9900 as well. It also hangs the phone about 20% of the time when I exit the car. Have to pull the battery to reset the phone.
2012 Passat with Fender system.
Happy to help.Thanks VeeDub, I always saw all these posts about streaming Bluetooth and how happy people were........, that TSB confirms why my Bluetooth sounds like shi#! I was playing in MONO.... Will definitely make an appointment before the Florida trip!
Edit for up to date info... called dealer and I'm bringing it in today to have that done... will post results afterwards.
Excellent!So, after my dealership refused to do the update, I had to get VW Customer Service involved. VW contacted them, and hopefully I'll get it fixed this week..
Hopefully it fixes the new problem of the system not restoring to the previous screen (presumably radio of some sort) after you hang up a phone call (or when Waze pushes a Bluetooth traffic alert).Just sat with the tech and showed him all 3 complaints... And how they work... Or don't depending how u look at it. They pulled it in and are pulling up the software change now. Tsb's aren't like recalls.. Gotta work them a little ;-) but the proof is in the update notes.
Update: apparently there is an update to the update... Was just informed there is a new revision to this tsb... Will post when I get info.
I forgot my PPW at home so I'll have to get the updated TSB# later on tonight and post it for all.Hopefully it fixes the new problem of the system not restoring to the previous screen (presumably radio of some sort) after you hang up a phone call (or when Waze pushes a Bluetooth traffic alert).
I'd love to hear what the update to the update actually does.
I dont know jf it was update related but ui of the radio looks to have changed for the worse. The buttons look like a bad 8bit atari rendering. On top of that there is the faded red almost pink border around everything like my radio is displaying a tribute to that susan b cancer lady that runs marathons every weekend.
It's a nice sunny 70 today and I checked my screen brightness setting and it was already set for dark. Maybe the next update will improve the graphics.^^ This.. I noticed a slight fade from top to bottom as well, lighter on the top than the bottom. Some color variations are noticeable as well. That being said, This could just be me not doing my homework but I never noticed that they have a section to adjust the screen brightness now with presets. IE: darker, lighter etc.. I adjusted said settings and almost got it looking normal again... It was 1 degree this morning when I started it up so on my commute I don't think the LCD ever defrosted from its "cold discolored" state.
I had a similar experience with mine. However my service manager was less than thrilled about finding it on a forum. He told me he couldn't look it up by a TSB number. I find that hard to believe since so many others here have been able to get it done with the TSB number. I had to make sure Bluetooth was off in my car before I'd get into it or I'd lose my podcast or audiobook location. Now I'm able to use the Bluetooth audio and not be fiddling with turning it on and off all the time. And the battery life last longer since the phone isn't playing the whole time.I had the update completed on my 30k service a few days ago.
I printed out the TSB posted a few pages back and showed the service writer then number. He had never heard of it but went ahead and put it on the work order.
Went to pickup the car a few hours later. Service writer said tech was able to update the software. Driving home I could not even get the phone to connect to the bluetooth and I was starting to get real annoyed.However, all it required was a phone reset and everything started to work again.
After driving for a few days I can confirm that there is no longer a bluetooth autoplay! This is great for me becasue with audiobooks, the old software would constantly have me rewinding to find my spot. Also, the blaring volume is no longer an issue and the sound quality is improved.
Make sure you reset you iPhone after you have the update done. Then everything should work great.
Overall I am much happier with the Bluetooth now.
Removing and adding the pairing back to the phone helped with some of the quirks I had after the update. It's quick and easy to give it a try.However it no longer is showing album info on the display...any ideas? Maybe I need to delete the phone and re-pair? Tech let me see software version which is 20120703A
The 9WZ is Europe-Only, unless you upgraded.Not sure this applies. In our cars I would suspect possibly some setting to module 2E (Media Player) or possibly module 77 (Telephone). I'll look at it this weekend. I'm a noob with VW programming, so I'm still playing around.
