Blue Driver?
JimMI
Michigan
2015 Passat TDI SEL
I bought one about a year ago. Used it on a Chrysler Town & County to determine why the ABS light was coming on. Pointed me to the right rear sensor error, sensor wire had a small nick in it.
I also used on a Ford Fusion for some transmission error codes being set.
Used it on my new to me Passat TDI and it confirmed my thought that the driver's seat heater was not working, showed an error code saying it was broke.
It does not do TPMS diagnostics, I have TPMS errors on the T&C, no help but then they don't claim to support TPMS.
andreigbs
Walworth Co., Wisconsin
N/A
If you're trying to decide between a BlueDriver and VCDS, save the $100 and put it towards the VCDS. It can do far more for your VW/Audi.
Having said that, the BlueDriver works great for what it is: a detailed code reader and troubleshooting device that can reset error codes for engine, transmission, ABS.
Alchemist
Lethbridge, Alberta
'04 ALH Golf
I already have VCDS, and it is great at what it does. The only problem with it is it only works on VW.
That is what I wanted to know. I am finding more other brands of vehicles showing up at my shop with ABS and Air Bag problems and need a diagnostic tool for them.
andreigbs
N/A
In that case, the BlueDriver will help tremendously. I use it on both of our diesels and it can give you a wealth of information.
And unlike the low-budget VCDS, it doesn't lock you to only several VINs.
bwk9087
MI
2007 Jeep JKU 1.9 ALH
Only problem I found with it, is that not every model is supported for all features. 2008 pontiac grand prix, abs not supported. Had to pick up a different scanner.
michaelmg
Australia
Volkswagen Touareg
Can you suggest a VCDS please? I am a frugal man but need one to get rid of the ‘Service Due’ message on my dash screen, after oil and filter replacement (plus all other filters and coolant when serviced today).
My Bluedriver doesn’t do this 🤣
hskrdu
Maryland and New England
There is really only one "VCDS" (as opposed to using the words Volkswagen communication diagnostic software to describe any software that uses the OBD port). VCDS is free software from Ross-Tech, but the cable costs money. The version you get is determined by your year/model and needs, i.e. see their website.
Lots of posts other than this short thread for your research- we even have a whole forum for OBD: https://forums.tdiclub.com/index.php?forums/obd-scanners.21/
Mixing the words "frugal" with a Touareg TDI is not common. Real VCDS is worth every penny...
