That is a good explanation of the blow off valve situation for the TDI's, Thanks Mickey. I think on a petrol motor that you don't need a blow off valve unless the turbo can spool up over 1 BAR, alot of them operate less than that and therefore don't have one. On high performance gas turbos, like the K04, a blow off valve is a necessity or the head could blow off instead!
It would be fun to hear the valve blow though if the TDI had one.
As far as compression ratios in a gas turbo car, they have to be reduced considerably, usually down around 8-8.5:1, when using a turbo. Of course, with the turbo in full action, the compression is still back up in the upper levels of 10.5-12:1, thereby needing an antiknock sensor to retard the timing under full boost. The operating temperature of a gasoline turbo is considerably higher than that of a diesel turbo by about 25% (750 C. vs 1000+C.).
