wackey4015
Hi I was having a lot of things going on with my Vw golf mk6 a long story short a doing the parts cannon on it. I seem to got it sorted which I taught so one of my last resort was to do a smoke test on it so I was looking around the engine there was no leaks so I just pulled out the dip stick and the was oil spitting out which got me in the face so went out got a compression test and on cylinder 2 I was getting 20 psi and 25 psi on other 2 and on the fourth piston I was getting 30 psi now to cut a long story short I’ve put petrol in the car a drove it no realise till it conked out then I knew what I did so my question been is should I change piston rings or should I get a second hand engine and hope for the best I’m assuming it the piston rings what do think I should do
