Phi1osopher
1996 B4V. I have begun intermittently loosing power (feels like loss of turbo boost pressure). My Glow Plug Light started blinking, and I retrieved CEL code P1247. My brake lights are all working correctly. When I measured the 3rd injector's resistance at the ECU, pins #11 (grey) & #12 (blue), I got varying numbers, mostly around 190ohms. (This was with the engine slightly warm... about 30 minutes after it had run for about 10 minutes on a warm day.) When I tested the resistance at the 3rrd injector, disconnected from the 'brown plug', the numbers were similar, but fluxuated from 190ohm to 140 ohm as I wiggled the wires. You can see in the photo I removed the sheathing to observe for damaged wires; I thought I had a short, but the wires tested good, with no breaks indicated when testing them.
I then tapped on the #3 injector with a screwdriver handle while observing resistance and it immediately dropped from 180ohm to 109ohm.
It looks to me like the 3rd injector sensor is failing, or at least sticking. Any thoughts?
Also,
I have been REALLY REALLY REALLY wanting to upgrade my injectors to .520's, turbo + chip with EGR delete to a stage 2-3 tune. Or something like that.
I don't want my desire to upgrade with a 'tune' influence my diagnostics. I have been struggling financially recently so upgrading my daily driver wagon has been pushed back to a lower priority.
Does this look like it's finally time to do it? Are the recommendations for a tune? I had planned on going with Kerma, any thoughts or recommendations there?
Thanks!
Also,
Thanks!
