Somehow the compression tester showed up right when I got home from work even though it wasn't expected till next week. The closest harbor freight is about an hour away so I assume they made an employee drive it up themselves, that or support your post office folks.
*drumroll*
#1 310psi
#2 290psi
#3 250psi
#4 220psi
Tried each cyl a few different times. Same results. That was 10-15 cranks each. 7-8 cranks gets a few puffs lower. So we are clearly out of the 400-450ish spec quite a bit AND right at or below the 275psi wear limit on 3 out of 4 cylinders AND a 100psi difference between them... well...
RIP little tdi. We barely knew each other. I thought you would love your turbo, I thought it would bring us closer together, I just didn't even know what signs of abusive oily turbos to look for. I'm so sorry.
*drumroll*
#1 310psi
#2 290psi
#3 250psi
#4 220psi
