eddieleephd
This morning I blew my turbo getting on the interstate. Engine started to run away and oil spilled out when I disconnected the lower boost hose.
I have not been able to achieve the desired fuel economy since I installed the 17 and have been considering reverting to the 15 and putting a smaller tune on.
This would likely require me to revert my nozzles from DLC1019's to the 520's I have in my parts inventory.
If I revert to the 15 I will also have to order an new boost hose as the present one is an OEM one for the 17.
So I am curious what others thoughts are on the situation. Pro's and Con's to either choice?
I got on the interstate and was pushing it to heat up and burn out any build up in the veins when there was poof and lots of smoke.
I was having some intermittent over-boost conditions and thought a little exhaust heat would help. That is until it was catastrophic failure.
So now I'm in a difficult place pondering the choices and could use some real insight.
Thanks in advance for beneficial feedback
