POWERSTROKE
Can this cause an over boost if it’s bad? I can suck and blow (yeah I know) on both ends of this thing....
I did the output test in vcds on the n75. In my other thread I noted it would make sort of a chirp sound and the normal thump thump. How can you tell if the thing is actually bad? My overboost happens rarely, and only on long hill climbs. Happened last Saturday doing a steady 85mph up a long grade on I-91. Them I can pound on the car incessantly on the flats and runs like a champ.It will cause NO boost from my experience, although I have only come across a couple of those bad over the years.
OVERboost is generally caused by either a sticking VNT mechanism on the turbo, or the N75 itself unable to vent away the vacuum properly, and allow the VNT actuator to return to the rest position.
So I know I need a check valve. I have had 2 rusty actuators so far. I installed the third last fall. Is it best to replace the check valve and n75 for what I describe? The actuator hood vacuum and seems to go down smoothly.That check valve isolates the N75 and the vacuum ball reservoir from influence of other components using vacuum.
If it does not work properly then the N75 valve may not have enough vacuum on hand to pull the vane lever actuator where it needs to go. Underboost, not overboost is the result.
If you sit there madly pumping the brakes, I suppose that you could thwart its capacity to keep a steady vacuum supply to the input of the N75 valve.
I often enough find the B/W check valve faulty when a turbo actuator develops a hole in the diaphragm and rust debris and dirt get sucked all the way back to the vacuum pump. The small nipple on the brake booster check valve assembly attached to the vacuum pump can get clogged as well and the N75 valve.
