perrya
Simply put, when I turn off my headlights, the left side front and tailights stay lit. The right side turns off. This started to happen out of the blue. I should say the daylight running lights and taillight stay lit, not the headlights. The hi-beams work normal.
Is this related to a blown fuse? What do I need to replace? Until fixed, I have disconnected the battery. To test, when I reconnect it, the DRL and rear light are lit indicating there must be an open circuit that has not closed.
2006 VW Jetta TDI
2006 VW Jetta TDI
