Sorry for the delay guys, needless to say it's been a while... Had quite a bit going on in the RL that's caused me to be away from the site for a while.
To answer quickly on the past couple of questions...
Awesome work Jared; very inspirational. I have a black TDI as well and am planning on doing the same retrofit over winter break. I'm thinking of ordering some FX projectors--do you think these will fit? They seem like they're the same size as the TSX projectors. How is the write up coming along?
You should be able to make pretty much any projector fit without issue, I but I personally wouldn't go larger than 2.5 inch projectors (which is what the TSX projectors are).
As for the write up, I'll have to start it again!
how did you remove the headlights?
I removed them with a few torx bits and some careful maneuvering... Removing the bumper isn't necessary, but it would make life easier if you have the time to do it.
I wanna do this, but I dont want the big chrome plated shrouds. I want the shrouds like in the Mk5 GTI/GLIs, where they glow when on. Would I be able to use the smaller lenses or are the TSX the best route? I noticed you cant get the smoked shrouds with the TSX lenses in this kit, which was referred by a VWOC buddy:
http://www.theretrofitsource.com/product_info.php?products_id=3893
You can use any shroud you like, as well any projector. I mainly chose the TSX projectors due to the popularity and OEM equipment... While I wouldn't say they're the 'best' route, I will say they worked out just fine.
The only thing I would have done differently at this point, would be using bi-xenon projectors for the high beam light.
I will be ordering a second set of headlights in the near future in order to redo both lights, as well as add a few new features that I'd like to have (including LED DRLs).
