mayday_soc
I’m looking to install Macan (Brembo) brakes up front (yes I know bleeding them is a nightmare) but I like the pad selection and the pad installation/removal process. If I swap out my front strut size and switch to aluminum knuckles will the killerbrakes.com kit bolt right up? Will the supplied brake Lines work? Also, should I go with Clubsport ,R, or GTI knuckles? I’m thinking R knuckles, endlinks (still running factory and I’m much lower), and 24mm front sway bar.
In the rear I’m looking at the Golf R brake kit from the same website. Again, will they bolt right on? What changes need to be made in the rear to upgrade to a vented disk?
Im aware this isn’t a true Big Brake upgrade. I do not track the car seriously. No, I will not be swapping out the master cylinder or brake booster. I need the calipers to fit with RSE05 17x8 (winter) RSE10 18x8.5 (summer). Im also aware this site isn’t ideal for cost savings, I’m fine with that, it’s more about convenience.
