big drop in fuel economy....winter blend already?
larrydk
Brookfield
Sportwagen
In the last two weeks my fuel mileage has dropped into what I normally expect in the winter (Chicago)....I assume this is due to winter blend? When do the stations normally switch over?
In Chicagoland? I would think they would have been changing a month ago.
Keep in mind, the engine management is going to make the engine get up to temp as quickly as possible. The only way it can do that is to burn more fuel. Colder engines take longer to get up to temp. So they will use more fuel. Which is why it is important to drive off right away, not let them sit and idle. The faster the engine gets up to temp, the less fuel it will use, and a warm engine is a happy engine.
Diesl
Chicago
'78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
If you are driving mostly highway, then it could also be due to the air resistance going up with air density, which is going up with the colder temps we are having recently. Going from 60F (~285K) to 30F (~270K) makes a (285-270)/285 = 5% difference in drag.
Tdijarhead
Lawrenceville PA
A winter front will help your engine warm up faster and stay warmer longer. It’s all about the heat of the engine.
pdq import repair
idaho
09 Jetta
Every year about this time fuel economy drops. Don't worry it will come back in spring. Drop is a relative amount anyway. My TDI at it's absolute worst is 10+ mpg better than my wife's car at it's absolute best.
narongc73
VA/OH
2006 Jetta TDI
my mpg gets better in the winter, since I'm not using the ac. Long trips do help though. Your mpg suffers when your trips are short, and even worse when it's cold out.
