Looking for output shots thoughPretty sure this was discussed and a quick search may reveal.
Consensus is that they are worth it.
Take our word for it, they are worth every penny.Looking for output shots though![]()
Go for a test drive at a local dealership.Looking for output shots though![]()
Please reconsider a PnP HId kitI couldn't justify the extra $1k for the lighting package. I had aftermarket HIDs in my last vehicle and loved them. I see there is a plug and play HID kit for the GSW now for ~$100 so I'll add that in the next few weeks.
I know the aftermarket kits are no substitute for the adaptive aiming with the lighting package, but it just seemed a bit steep in price for me considering how common these features have become on the current crop of autos.
Can you elaborate? I had zero issues on my SUV with a Kensun 6000k HID kit. Zero. Nobody flashing their high beams at me, no reliability issues. Zero.Please reconsider a PnP HId kitAt least do some research on why they are a bad idea for driver and oncoming traffic.
I'm not a fan either, but I will say some of the latest HID's are designed for reflector housings. Even Subaru offers them as factory options in the Forester, HID's in a reflector housing that is.Please reconsider a PnP HId kitAt least do some research on why they are a bad idea for driver and oncoming traffic.
Yeah, that is true...any projector is better than no projector with HID bulbs. Reflector housings are problematic because of the way they handle the light and keep it out of oncoming traffic's eyes. A projector has a cut off shield to do that and a lens to focus the light in the right places.Can you elaborate? I had zero issues on my SUV with a Kensun 6000k HID kit. Zero. Nobody flashing their high beams at me, no reliability issues. Zero.
Prior to installing the HID kit I would get about three months out of my low beam bulbs (issue common with that vehicle). I had almost 2 years on the HID kit when the car was totaled three weeks ago.
Edit: After doing some reading, I can say that the reason I didn't have any issues on my last vehicle was because it had projector low beams. I haven't looked at the GSW. If it doesn't have a projector setup, I won't install an HID kit.
All GSW's have this feature....it's the fog lights being used as cornering lights, you could've (chances are) engaged that on your A6 w/ VCDSAnd the final feature of the lighting kit are cornering lamps that come on when you make a shaper turn at an intersection. This is a really nice feature that the GSW has that my A6 does not.
No one... It's generally NOT recommended to use HID bulbs in reflector housings that were designed for a halogen bulb.So, who makes the best aftermarket plug and play lights for the MK7?
Thanks!
Thanks!
Osram makes the best...they are called H7 Rallye's, and they are basically H9 (which are 65w) built onto the H7 base. Light output goes from 1300's to 2100's, which is higher than the factory HID lights.So, who makes the best aftermarket plug and play lights for the MK7?
Thanks!
Does this create the same issues that HID elements in a non-projector housing creates? Do you get people flashing you at night?Osram makes the best...they are called H7 RC's, and they are basically H9 (which are 65w) built onto the H7 base. Light output goes from 1300's to 2100's, which is higher than the factory HID lights.
Now if you are looking for color...again, just get a coated bulb and be happy, color is not light output
I'd be curious to see the light pattern of those projectors. It isn't a oem housing but the price is right for seeing how it does with some hid bulbs.NGP has a kit with new housings for $599
http://www.ngpracing.com/newstore/b...led-uu-drl-and-turn-signals-mk7-golf-gti.html
I'm not heartbroken about not ordering the lighting package. I felt it was too high of a price for technology that is now standard on many cars. Repairing the system down the road isn't an appetizing thought either. Pricing will only go down on retrofit kits such as the one posted above.
There are some very good bulbs that don't have any coating on them. That's generally the best way to go if you're looking for light output. Coated bulbs reduce the amount of light in favor of color temperature.Does this create the same issues that HID elements in a non-projector housing creates? Do you get people flashing you at night?
I hate the short lifespan of Silverstars, but I prefer the whiter light at night for contrast on the road.
Thanks! I would just like better output similar to our former MK6 Xenon clarity. We did not get a lighting packageOsram makes the best...they are called H7 RC's, and they are basically H9 (which are 65w) built onto the H7 base. Light output goes from 1300's to 2100's, which is higher than the factory HID lights.
Oops! I meant to say: Who makes good complete replacement housing with better light, not bulbs per se, but complete units.No one... It's generally NOT recommended to use HID bulbs in reflector housings that were designed for a halogen bulb.
The only true (plus coding and possible wiring work) plug and play is a HID projector/headlight assembly directly from VW. Prepare to pay way more for the headlights alone compared to just buying the lighting package from the dealership when you buy the car.
H7 Rallye's, not RC's are what is needed (doh). I'm not sure how the RC's would work, but I do think they are in the new Forester as the HID's, they are not using a projector housing, so the RC's is all I can think of to accomplish this. I've had RC's on my mind reading up on them, but still not going to purchase them as I'm not sure, and would need a ballast to get them going.Does this create the same issues that HID elements in a non-projector housing creates? Do you get people flashing you at night?
