PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
I have the hanswerk cruise controls. Running the fast forward universal VSS sensor. Have my adjustable vss signal box dialed in to within 2 or 3 mph at 50mph.
I'm running the factory Passat gauge cluster so it has a vss input from my universal vss to run the speedometer and an output feeding the ECU.
My clutch feed is wired directly to 12v constant to ECU. My brake switch feeds ground at rest and 12v st brake to ECU.
I've double and triple checked my cruise control wiring.
In vss I can see when I turn the cruise control on, it also lights up the dash crusie light. It even changes the block when I turn it on or press the brake whike on..
It does however throw a soft cel when I turn on the cruise control and cruise control light. It says something along lines of signal not recognizing.
Any tips for how to get this functional? Thank ahead of time.
