Machineman
- Joined
- Aug 25, 2014
- Location
- ontario canada
- TDI
- 2007 RS4 Titanium 3.0TDI & 2013 Touareg TDI & B6 S4 BHW Swap Biturbo
I made up a 7mm phenolic intake spacer and after realized that the manifold hits the exhaust manifold so this is what i came up with.. i like the way it turned out practically looks oem and i can finally do away with block off plates while i was in the process i figured i would bore the oulet from 1.280 to 1.580 what a difference spools the turbo sooner the exhaust is quieter great mod considering it was free and i figure it would help at the high rpm once i put a bigger turbo on
For those considering a phenolic intake spacer it definitely makes a huge difference in intake manifold temps it only get warm to the touch instead of the same temp as the cylinder head
I think my egts are a tad bit to hott
does anyone else have a glowing manifold?
