BHW manual swap to keep or delete BSM
QR12
California
2004 Passat GLS Wagon
Currently manual swapping my 04 Passat wagon. I was originally going to delete the BSM but today I found that I have a gear driven BSM instead of a chain driven. I was hoping to get some input from other members that have manual swapped.
50harleyrider
charleston,wv
2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
Your fortunate. Don't do anything. The geared BSM is the ultimate fix. I have heard they can fail Via the oil pump drive but mines been going great for years and if you have miles on it, keep it and enjoy the smoothness.
QR12
California
According to the receipts from the previous owner mine should have around 100k on the geared BSM.
zzdiesel
sask. mostly now Wa.
05 passat tdi Geared BSM and Bewcam 2nd 2005 deleted ,converted and bew cam stage 2 Malone3 tune.
Should you have the oil pan off you could check the hex shaft. It could also be turned end for end and have new driving surfaces.
Windex
Cambridge
05 B5V 01E FRF
There are two versions of the gear driven updated BSM. 70 mm shaft and 100mm (or thereabouts). There have been documented instances of failed shafts on the smaller version which have (very smoothly) blown engines due to oil starvation. Confirm the length of the oil drive shaft. If it's the shorter version, delete. Longer, keep.
50harleyrider
charleston,wv
I don't have a clue which one mine has but I sure wouldn't pull the pan to verify and then spend as much as the car is worth to delete it. these cars are just too old now to ask for problems
auntulna
Springfield, MO
05 GLS Passat wagon, mit panzer plate
Agreed 5HR, but what should the thoughtful Passat owner spend money on? The stereo? A seat cushion? (Only need one)? Flush the heater core, or wait till spring comes again? Maybe one new headlight? Replace the front tires? These are the questions the 200K plus owners face....
yahmon
canada
04 passat tdi 6spd stage2 webasto TC3 , 04 passatW8 6 spd, 10 Jetta TDI 6spd stage 1
Keep for sure, got the same setup with FRF 6 speed and no vibrations anywhere.
PickleRick
Greenville sc
Or pull geared balance shaft assembly, sell and then take all the money you make off of it to fund your delete/timing belt and 5 speed conversion!
Replace the rear water hose T under the tandem pump, the rear temp sensor, new tandem pump gasket(tandem pump if you can swing it) and the thermostat while you have it out. I had to replace all those within a year of my conversion, would have been so much easier to do all that with the motor out.
yahmon
canada
Why you pull the motor out?
PickleRick
Greenville sc
You can swap out the trans for the 5 speed conversion while the motor is installed but you have to loosen the subframe requiring an alignment of said subframe after reinstall.
You can also do the delete in the vehicle. I wouldn't recommend doing either job in the car without a lift.
It much easier to remove the engine and trans together, do the delete on a rotating engine stand. I don't like working on my back laying on the ground. Put the new trans back in attached to the engine. Feed the clutch line BEFORE putting the engine and trans back in. Or use the stainless braided line, then it doesn't matter what step its installed.
yahmon
canada
I suppose if you doing the delete and don't have hoist it maybe it easier. The subframe I simply put back in place aligning the bolt head prints and worked like a charm, no alignment needed.
