dlai
- Joined
- Jun 6, 2002
- Location
- The Insane Asylum Known As CA
- TDI
- 2005 Passat, Stonehenge Gray, 2002 Black Golf 5M
Brad:bubba said:I live in Monterey CA. Can you give me more detailed info on who you used to do the BS work.
Thanks Brad
There are very few upgraded cars running around in CA. There are two in Northern CA, but the work was not done in the bay area. They were both worked on in Harv's shop in Whittier, CA. Mine was done by Oilhammer and Bogstomper's was done by Harv. There are no shops in Northern CA that I'm aware of who has done this upgrade and I would not trust any shop to do this if they have not done it before. If I were you and you do not want to do the work yourself, your option is to do what I did and drive down to Whittier. Harv was trained by Oilhammer and is very well versed in doing the upgrade. He's done quite a few already and your car would in good hands.
Hope the info helps. Good Luck!
