BHW/ALH VE Hybrid...
jmodge
Greenville, MI
I just looked an an ALH I have on a stand. The water pump clocks differently, not sure about the size, but I bet IBW could tell you. The upper roller is in the accessory and pump bracket. Idler is in the head, and the lower roller is, if you follow a horizontal plane, within the bottom of the water pump bore away from the plug
jmodge
Greenville, MI
A little higher than that roller it appears and smaller in diameter
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
Wow, thanks for all the observations, advice and the cjaa picture. I'm not discouraged yet, I welcome the challenge, sounds like fun ! I'll call yards Monday to get prices on the local cjaa core and used bhw pistons.
Ross
looking at the pic in this ^^ post you'll have to drill/tap both lower idle roller holes. It does appear that an ALH front seal holder will bolt right in. You can the chamfer WP hole by carefully sanding with a drum attachment, as long as the bore matches that of an ALH.
jimbote
you're right, bolt clocking is different, plus the cjaa water pump hole looks HUGE compared to the ALH pump bore and it appears to protrude much farther out than the ALH.
Ross
Maine
01 Beetle ALH 5speed
Great, this all sounds very encouraging. Thanks so much Jim. By the way I have a 97 Tacoma Parts truck in the woods if you need anything. It's a standard cab 2wd 5 speed.
Ross Converse
jimbote
Ross Converse
i think you need to read my posts after that...does not look like the cjaa will work at all for a VE setup.
Ross
Maine
Okay, I've read through your posts and I admit I'm a bit confused now, I'm sure this is obvious but I don't have any experience with this motor. Could you summarize for me the biggest problems you see that would have to be overcome regarding the front of the motor. I understood about the water pumps being different.
jimbote
looking at the front of the two blocks the cjaa will NOT work as a VE hybrid. Read my previous post about the water pump.
Ross
Maine
Okay thanks for your time and expertise Jim, I'll continue looking for a bhw that I can afford. This is the safe way to go since you've worked it all out so thoroughly.
Have a good weekend,
Ross
jimbote
two more closeups, one of an ALH and one of a cjaa. They don't look terribly different from these angles. Another difference of note is no machined hole for the hard metal pipe. There is a nipple toward the rear of the block that may be for a heater hose. Screenshot_20201024-205738_eBay.jpgnScreenshot_20201024-205908_Chrome.jpg
Ross
Maine
a couple of things i would make sure of first. Water pump bore and impeller depth. clocking looks the same. I'm sure you can drill the cjaa for the two rollers.
Thanks for the pictures. Maybe wishful thinking but it sounds like you're still leaving open the idea this might work. Did you notice that I'm going mtdi so I don't need the reluctor or crankshaft sensor?
Ross
Maine
I was also thinking if the blocks water pump bore is bigger than the alh water pump, possibly a sleeve could be machined to slip over the water pump to increase its diameter to match the block.
fjdiesel
MN
76 fj40 w/05 LIberty CRD 2.8L diesel
sweet! i'll be building another bhw/alh hybrid in the not to distant future and i'll amend this thread with new tdiclub hosted photos
Did you end up doing another BHW/ALH build?
Ross
Maine
Hi folks,
I decided to play it safe and not reinvent the wheel.
I just bought a supposedly good bhw short block from a Pennsylvania yard for $200. I'm going to build a hybrid with my good running alh and keep it electronic and forget the mtdi I'd originally planned.
Thanks for all your help. I feel I've made a wise choice.
Let the fun begin !
Ross
Ross
Maine
i have not, but i have all the parts including head studs, four or five ALH heads, and two BHW short blocks.
Hi Jim,
Thanks for sharing all your hard work and innovations with us, I never would have started my alh/bhw hybrid without your detailed instructions.
Ross
Well the core crank part is essentially the same thing, so yes, it will fit just fine. The difference is the tone wheel (which bolts on) and the oil pump drive gear (which presses on).
I do not have the two cranks side by side to compare what else (if anything) may be different about them, though.
mtbr297
Ft. Worth, TX., USA
2015 Golf TDI, Seat Leon FR PD 150 6 speed.
And the larger rod journals.
Is that different too? I know the rods and rod bearings are different, but I was thinking different design, not also different size. I've dealt with both, just not at the same time, that's why I wasn't sure. The main bearings and main cap bolts are the same, I do know that.
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
It seems BHW and ARL rods are dimensionally identical. Not sure which one is 'better', probably the set one has in good condition... LOL
Douglas
PakProtector
AnnArbor, MI
I think 48 and 51mm rod journals. No difference on the mains... :) Would love one of these 2.0L 'ALH' engines...should probably collect the bits.
Douglas
jimbote
Over 200k miles on this hybrid so far. I recently did timing belt #3 along with valve guide seals as it was smoking terribly on startup. The guides were pretty worn but I figure I can get a few more years before swapping in a fresh head.
Ross
Maine
Wow that's impressive!
ecala001
California
03 golf
love this thread! I'm getting near on starting this project.
If I were to keep the ALH block, what can I swap from the bhw block to make it work?
I currently have a spare of both.
BustedBolts
PA USA
2001 and 2002 Golf's
ARL and BHW do not have the same rods. BHW/CBEA/CJAA do tho, ARL are 16mm thick, and the BHW are 19mm. However the journals are all the same. I have CJAA rods in my Pd150 block, using Pd150 crank and pistons, with an ALH head.
Ross
Maine
Hi all,
So just to clarify, cjaa rods and crank (with the tone wheel and sprocket swapped) can be used to upgrade alh strength using all the other alh parts. CJAA engine cores are plentiful on carpart.com and there's one in my area.
Thanks, Ross
jimbote
Hi all,
Thanks, Ross
There's no provision on the cjaa or cbea crankshaft for the tone wheel. Also the ALH Pistons will not fit the tapered end rods. You could use BRM Pistons. Or just find a BHW short block.
