Midsummer bump.
I now have 100k on this swap.
- The clutch chatter is completely gone, pedal effort is lighter, than when the clutch was new, but still heavier than stock.
- I still have the "spare" 01E transmission in the car, the FRF that Matt Whitbread setup the bearing clearance on is still sitting in the basement.
- I have lost two driveshafts (left, then right) due to torn inner boots. I went with smaller (108mm I think) flanges on my 01E to accommodate common (in N/A) 1.8t axles. I replaced the left side in a parking lot in Miami with a cheap Chinaxle in order to get home after vacation. It lasted roughly 4 months before the inner boot on it ripped and it too started to vibrate. I obtained some used axles and swapper the inner joints from left to right and vice versa. Cleaned, new grease, and rebooted. The car is now much smoother on acceleration. The old worn axle, and the chinaxle both had vibration on acceleration, the OEM swapped inners are smooth at all speeds.
- Generally all-around liking the car - very good to drive. I am BSM deleted, and the 2000 rpm vibrations are noticeable in cold temps (more so below freezing) but get better as the engine and the mounts warm up. I barely notice in the summer time when the ambient temps are 20degc / 70 degf or higher. If I lived anywhere south of Kentucky, I would not hesitate to just delete the BSM and be done with it.
