rocketboy52
Just Read this thread from Start to finish. Lots of good info. I'll be interested to see how the manual rebuild goes as well. I still have a question about the 01E 6 speed. It looks like this is the way to go if you want the best mileage possible, but I keep seeing posts that "Say" that the 5 speed transmissions have the same top gear ratio as the 6 speeds, but no one has posted what their acutal top gear ratio is for their 5 speed. I think that 01E is the base transmission number that could be "lots" of different VW transmission codes. For 6 speed trannys I think I'm now looking for one of the following:
GVS
DQS
FFN
FRF
FRK
Which are all 01E tranmisions right? I found a West coast tranny shop that specializes in rebuilding 01E transmissions, but the first guy on the phone didn't know if he had any TDI infomation. He said he had "all" gear ratios avalible so I wanted to specify which VW tranny code ratios I'm looking for.
Previously in this thread the ratios for
GVS, DQS, and FRF have been given. Should I consider any other ratio sets? I've read about 6 speed humming at 2000 rpm and I'd like to not have that issue after going through the hassel of swapping the car over. Thanks for sharing your experiences!
GVS
DQS
FFN
FRF
FRK
