BHAF for B5.5
ruSSrt
Seattle WA
Is there a such thing as BHAF (big honking air filter) for TDI's? It's pretty big in diesel truck community and since I got EGR deleted I'm thinking about getting MAF sensor delete and also getting rid of stock air box. Just to make that diesel breath a little better.
Mozambiquer
Versailles Missouri
The stock air filter will work best still. I haven't seen any kit for an aftermarket filter, and with a TDI you want to avoid oil type filters, as it will ruin your maf sensor.
ruSSrt
Seattle WA
I never used or will use oiled filters. But I'm researching to see if I want/need to do MAF delete also.
Mozambiquer
Versailles Missouri
My understanding with the MAF delete, it'll have a bit higher power potential (not sure why) but economy will be a little bit down, since it won't be adjusting fueling by how much air volume, just by how much air pressure. But that would remove the inhibition for having an aftermarket air filter.
PickleRick
Greenville sc
I dont see any upside to an air filter upgrade unless you're putting on a bigger turbo. The stock turbo is a tight fit on the air filter box so going much bigger(or compound?) would require the intake system to be reconfigured. Along with a FMIC upgrade!
Ive seen a lot of all out alh builds but not a BHW so it would be interesting. I made a post about bigger or compound turbo set ups that would start to spool around 1500 rpm and still be making power without being a hair dryer at 3600 to 3800 rpms (lots of boost to keep egts down) the idea being an engine that sees lots of load but the turbo(s) and manifold stay cool enough to not burn up a turbo blanket and heat wrap. I've been itching to toss one of my spare BHW motors into a boat where the motor sits in a hatch so I can't have glowing red exhaust parts.
Ive also been wanting to toss the bhw into a 4x4 for years now but the mpgs, comfort and handling of the 5 speed converted bhw is hard to beat. Its not a boring ride like an accord or Camry.
Sprocket
Sprockette's hubby
MI
2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
I have a 2260 turbo on mine with the stock air box setup and it works perfectly fine. I'd personally never use a cone filter AKA hot air intake that sucks in hot air from inside the engine bay.
Yep, the stock airbox works perfectly fine, and does a great job at actually keeping dirt and grit from the engine.
ruSSrt
Seattle WA
Thank you guys for your reply. I'll be keeping that stock box with good filter in for the life of that vehicle. It is my fun daily driver to work and back and definitely not looking to mess with it. I love my 37mpg and will see if I get any more after EGR delete.
Tom in PT
Twilight Zone, WA State
The Right Foot mod will probably do more to increase mpgs than anything else, such as EGR delete.
I see large differences in mpg (42-50 hwy) depending on how fast I drive, how I manage hills, etc. I clean out the EGR valve from time to time.
https://en.wikipedia.org/wiki/Exhaust_gas_recirculation#In_diesel_engines (3 percent power and efficiency loss from EGR, but at the cost of spewing out a lot more NOx into the atmosphere which is poisonous)
