05MK4TDI
(2005 Vw Jetta mk4 BEW)
i was cleaning out my intake manifold, and on reinstallation of the manifold and egr cooler, i accidentally broke the arm of the “intake manifold vacuum actuator.” it’s located on the passenger side of the engine, shaped like a little circular plunger with an arm (pointing towards the front of the car) going to a pivoting bracket on the intake manifold. it’s just below the Anti Shudder valve, and is made of plastic. when i reinstalled the intake system, i took it for a drive and under high boost, high load, up until VGT actuation i get a very loud squeal and a “flat spot” in my power curve. i have no clue what creates this, and i’m not sure if that broken arm on that actuator could create that noise. i have a new one that is shipping right now but it’s not gonna be here for a week or so, and i’m kind of scared to drive my Jetta because this noise did not happen before and i don’t want to damage anything further. any thoughts? i saw a video online and a guy said that he had lost braking power and boost pressure because his vacuum pump main supply nipple cracked, causing a vacuum leak. (nipple located on vacuum pump directly below the intake pipe. to the right of the engine, left of the air cleaner, and on the back side of the vacuum pump.) i thought it could be that intake manifold vacuum actuator arm being broken but i don’t know what to do anymore. thanks in advance!
-Jaxon
(for pictures of the part i broke, search up “1.9tdi bew intake manifold vacuum actuator”)
-Jaxon
