Hatchet Ratchet
i replaced the cartridge in my 2004 BEW KP-39.
what position should the mechanical stop set screw be set at for the position of the vanes when the actuator is fully pulled down? the lever arm on the vanes also bottoms out on the cap screw that mounts the smart actuator to the turbo housing, so somewhere there or above is what i would presume to be correct?
how do you know or where can you measure from to know if your set screw is at the correct position to limit the bottom end of the vane position?
