jptbay
Having trouble with this car (A4 BEW Jetta Tiptronic), and I can’t figure it out. Been trying as time will allow, but the pressure is on now as I was hoping to have the car running for my daughter who is starting college soon.
Car starts and runs, but no power.
No codes.
Fault showing in MAP sensor. VCDS shows 2193 mbar at all times – running or off. Group 22 Shut-off status shows 002 system malfunction. So, this implausible high boost signal is triggering Limp Mode.
Tried new 3 bar map, no change. (car is tuned)
Tested wiring continuity from map plug to ecu. No wiring faults in this circuit.
Read as much as I could find about related problems. Some reported other faults in unrelated harness’ can give wrong reference voltage. Usually O2 sensor or N18. See thread here
N18 passes function test in VCDS. Turbo actuator responds as expected. Visual inspection of N18 harness looked OK.
I took apart the front engine harness, all the way back past the battery. Could not find any faults.
Inspected O2 harness from junction under car, up firewall to main harness. No obvious issues. Bought new O2 sensor to try. No change.
Any ideas about where to look? I’m just about ready to buy a whole new engine wiring harness.
I don’t have much hair left to pull out.
Thanks for your help, John.
No codes.
