gvan
Today on a 90 mile highway trip our 05 Jetta Wagon started to shudder under load. Downshift to higher RPMs smooths it out. It was mild at first but by the end of the drive the car is almost undrivable. Idle seems a little rough also. Just did an oil change, replaced the air filter, and fuel filter changed a couple of weeks ago because we were getting some intermittent hesitation on acceleration over the past month.
VCDS below from this evening. The MAS airflow sensor issue has been chronic for over a year since just before our turbo went out.
What to look at and in what order? Injector connection, harness, injector?
Anything here to suggest camshaft or lifter damage? Owned this car since new and have always used the correct oil at regular service intervals.
Thanks in advance, anyone willing to offer insight here.
vanman
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWSR61J25W047009 Mileage: 392130km-243658miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 R HW: 028 101 181 2
Component: R4 1,9L EDC G000SG 0282
Revision: 12345678 Serial number: VWZ7Z0D0759191
Coding: 0150031
Shop #: WSC 23411 444 58605
VCID: 2D5FDE74B73D7DEE88-513C
3 Faults Found:
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 2016 /min
Torque: 0.0 Nm
Speed: 92.0 km/h
Temperature: 30.6°C
(no units): 135.6
(no units): 0.80
Temperature: 90.0°C
18074 - PD Unit Injector; Cylinder 1 (N240)
P1666 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 2184 /min
Torque: 226.0 Nm
Speed: 99.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Inj. Quantity: -0.14 mg/str
Temperature: 44.1°C
(no units): 16.0
16685 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
RPM: 819 /min
Torque: 58.0 Nm
Speed: 35.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Inj. Quantity: 2.96 mg/str
Temperature: 78.3°C
(no units): 128.0
vanman
76
Coding: 0150031
3 Faults Found:
Freeze Frame:
RPM: 2016 /min
Torque: 0.0 Nm
Speed: 92.0 km/h
Temperature: 30.6°C
(no units): 135.6
(no units): 0.80
Temperature: 90.0°C
Freeze Frame:
RPM: 2184 /min
Torque: 226.0 Nm
Speed: 99.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Temperature: 44.1°C
(no units): 16.0
16685 - Cylinder 1
Freeze Frame:
RPM: 819 /min
Torque: 58.0 Nm
Speed: 35.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Temperature: 78.3°C
(no units): 128.0
