craig01b
I got a note that a BEW cam will work in a brm engine, albeit for economy and not performance.
Any input?
Any input?
So, with the BEW stage 2 cam in my car, would I be better off with a + or - torsion value? I had it at 0.0 for a long while, but now am at +2.0, doing some experiments to try to lessen the large cloud of startup smoke.If you want to increase the rate of injection you need to increase the rise, to do this you need to advance the injection lobe which increases the average rise rate(advancing the rotation of the cam increases the slope of lobe and injection takes place higher on the lobe effectively injecting the same quantity of fuel in a shorter period of time).
I just reworded what Kerma said so people with a BEW cam in a BRM may find better performance by adjusting torsion. Loosen 3 screws and rotate sprocket counter clockwise to increase rise.
The unknown author could be talking about a gas engine where intake is dominant. If you consider a diesel maybe I want the exhaust valve not to open sooner but later, maybe plus 3 is to much and I am going back to plus 1 degree. I don't have VCDS yet and use a dial indicator. Be interested in your result.Well, I tried +2.0 for torsion value for a few weeks and a couple tanks, and my MPGs really went down. It's hard to tell exactly how much because there are so many variables, but I'd say I took a 2-3 mpg hit. I'm now trying -2.5. We'll see how that goes.
I loosened the 3 bolts that hold the sprocket tight, then turn the center bolt clockwise (timing belt holds the sprocket in place). Center bolt moving clockwise moves torsion to the + side, counter-clockwise to the - side. Very small movements produce large results, so you have to be very careful, as I'm sure you know. I detect a smoother running and starting engine with the -2.5 torsion. I'll try this for a while and see what MPG does.The unknown author could be talking about a gas engine where intake is dominant. If you consider a diesel maybe I want the exhaust valve not to open sooner but later, maybe plus 3 is to much and I am going back to plus 1 degree. I don't have VCDS yet and use a dial indicator. Be interested in your result.
Edit: to get +2 torsion which way did you move the sprocket, counter-clockwise? or clockwise?
Also remember if you have a smoke problem, you should check egr, inter-cooler pipe leaks, vacuum leaks, and then Maf and turbo graphs for proper response.
